UPGRADE HEATER?
  • UPGRADE HEATER?
    Anybody ever tried to improve the heater/ fan? I've had 4 festivas and all of the heaters don't produce.....................much!!
    Glad you asked!
    I'm currently working on a woodburning stove upgrade as we speak.
    Piezoelectric ignition, one into four "header style" smokestacks, custom paint job (moose and penguin scenery) and automatic ash ejection feature are some of the highlights!
    I'm currently looking for a nice cordwood trailer to haul the fuel.
    It'll be fantastic!
      only Karl....
      Jim DeAngelis
      kittens give Morbo gas!!
        Yeah a B6 swap makes enough heat.
          Karl, "GOOD LUCK" with your woodburner.............................you obviously need something to do!!!!!!!!
            ha ha
            but seriously, a blower motor that could push air faster would be cool. I find mine on max is really weak.
            89SX funtop! Fully loaded!
            RIP 90LX
              Just remember, more heat less gas milage.
              David
                Find one of those gas heaters they used to put in air cooled VWs. I had one way back when; worked great :-)
                    Originally posted by stefan
                    ha ha
                    Have you looked at your heater core? it could be plugged causing a reduction in air flow. I know mine seems to blow pretty good when I have it on max, I have actually been using number 2 instead cause I find it blows more heat instead of acting as a cooling fan when the car is idling.
                    90 festiva BP/G25MR swap, spec v seats, aspire brakes, FMS springs, round headlight conversion with HID's, custom exhaust, fiberglass hood, and a whole lotta bodywork
                    BEFORE AFTER
                      The heater in my winterstiva is by far the best Festiva heat I have had. I have to turn it down even when ts real cold outside, it will roast you out!
                      93 GL modyfied!!!
                      :fish:
                        Someone needs to pioneer the hotrodding of Festiva heaters!!
                        I want a V-8 DOHC heater core with an oversized blower.
                          A person should also check their thermostat... There was a couple posts about it here not to long ago... Get the proper 2 stage one not the cheap single stage bulk parts store replacement....
                          Here read this...
                          BEFORE AFTER
                            where can i buy one of those good stats at?
                              I had a festiva with the lame t-stat and it never hit the bottom (cold end) of the operating range. It ran cold all the time. When it was 15 degrees outside it would still roast me out. I've never had a festiva with a bad heater.
