Wow dude - that looks great! Congrats.
Finally, i have pictures of the build (so far). 56k beware.
you missed a spot lol. seiriously, beautiful car, cant wait to see it complete
Mike, AKA the sasquatch
The exterior is not complete there is no wiper LOL !!! Very nice build !!!
MORE pics of the engine!!!! what did you do to the exhaust manifold? there's more studs there than i'm used to seeing. what compression are you running, what turbo trim, what cam.... you know, the works...Trees aren't kind to me...
WOW!! just truly amazing!!! keep up the awesome work!!
Wow. You guys are fantastic. You always say such nice things.
I mean it. I am completely blown away with the support you all offer. Thank you everyone....
I can tell you MOST of what's under the hood (in parts) that i can remember, though i am not entirely certain of a few 'TUNING' options.
For starters- the charger is a .63 trim (I'm sure?) Garrett GT30 Rollerbearing unit, with Turbosmart 45mm external gate.
Exhaust manifold is 1 1/2" mandrel pipes- HPC coated- into 2 3/4 dump-and out (gate is plumbed back).
Cams are completely standard- though i am fortunate enough to have the 16valve equipped head to start with.
As for engine parts....
engine and engine bay
crack tested and x-rayed block
custom Venolia forged pistons
custom Venolia forged rods
balanced bottom end
'VERY' mild head polish
cc'd head chambers
customised inlet manifold
custom plenum
Sard 800cc injectors
customised fuel rail
braided fuel lines (engine bay)
sard fuel pressure regulator
washable aluminium high flow fuel filter
aluminium -6 fuel lines (underbody)
custom surge tank
Bosch fuel pump
60mm throttle
DNA 15"- 17" (core) front mounted intercooler, with customised tanks
custom 'HPC' coated 1-1/2" mandrel bent, match ported exhaust manifold
Garrett GT30 rollerbearing turbocharger (HPC coated exhaust housing)
K&N pod filter in custom airbox
Turbosmart 'Progate' 45mm external wastegate
Turbosmart blow off valve
2-3/4 mandrel bent stainless steel exhaust, (dump pipe polished)
Catco high flow 3" catalytic converter
dual 4" Supercat stainless steel mufflers, with dual customised 3" exhaust tips
stainless steel oil catch can
customised rocker cover
stainless steel plumbing
odyssey dry cell battery with custom mounting brackets
billet radiator cap
customised billet oil dipstick
balanced flywheel
customised heavy duty clutch
all bolts replaced with stainless buttons
Motec M4 clubman computer
custom strut brace
mick thats so sharp it almost makes me want to fix up the egg instead of the festy. . .
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
that is AMAZING Mick!!!!!!!!!!!!~Nate
Current cars:
FOTY 2008 winner!
WOW! Talk about sano! That is breathtaking what you have done!
MichaelHave owned 9 so far
