Finally, i have pictures of the build (so far). 56k beware.
    Wow dude - that looks great! Congrats.
    Simon - pimptiva.com
      OMG! :shock: I am speechless, your car looks unbelievably beautiful!
      93 GL modyfied!!!
      :fish:
        you missed a spot lol. seiriously, beautiful car, cant wait to see it complete
        Mike, AKA the sasquatch
          The exterior is not complete there is no wiper LOL !!! Very nice build !!!
            That is the best Aspire..err..Australian Festiva I've ever seen. Well done! :thumbright:
              MORE pics of the engine!!!! what did you do to the exhaust manifold? there's more studs there than i'm used to seeing. what compression are you running, what turbo trim, what cam.... you know, the works...
                WOW!! just truly amazing!!! keep up the awesome work!!
                  Wow. You guys are fantastic. You always say such nice things.
                  I mean it. I am completely blown away with the support you all offer. Thank you everyone....
                  I can tell you MOST of what's under the hood (in parts) that i can remember, though i am not entirely certain of a few 'TUNING' options.
                  For starters- the charger is a .63 trim (I'm sure?) Garrett GT30 Rollerbearing unit, with Turbosmart 45mm external gate.
                  Exhaust manifold is 1 1/2" mandrel pipes- HPC coated- into 2 3/4 dump-and out (gate is plumbed back).
                  Cams are completely standard- though i am fortunate enough to have the 16valve equipped head to start with.
                  As for engine parts....
                  engine and engine bay
                  crack tested and x-rayed block
                  custom Venolia forged pistons
                  custom Venolia forged rods
                  balanced bottom end
                  'VERY' mild head polish
                  cc'd head chambers
                  customised inlet manifold
                  custom plenum
                  Sard 800cc injectors
                  customised fuel rail
                  braided fuel lines (engine bay)
                  sard fuel pressure regulator
                  washable aluminium high flow fuel filter
                  aluminium -6 fuel lines (underbody)
                  custom surge tank
                  Bosch fuel pump
                  60mm throttle
                  DNA 15"- 17" (core) front mounted intercooler, with customised tanks
                  custom 'HPC' coated 1-1/2" mandrel bent, match ported exhaust manifold
                  Garrett GT30 rollerbearing turbocharger (HPC coated exhaust housing)
                  K&N pod filter in custom airbox
                  Turbosmart 'Progate' 45mm external wastegate
                  Turbosmart blow off valve
                  2-3/4 mandrel bent stainless steel exhaust, (dump pipe polished)
                  Catco high flow 3" catalytic converter
                  dual 4" Supercat stainless steel mufflers, with dual customised 3" exhaust tips
                  stainless steel oil catch can
                  customised rocker cover
                  stainless steel plumbing
                  odyssey dry cell battery with custom mounting brackets
                  billet radiator cap
                  customised billet oil dipstick
                  balanced flywheel
                  customised heavy duty clutch
                  all bolts replaced with stainless buttons
                  Motec M4 clubman computer
                  custom strut brace
                  • #24
                    A couple of older engine bay shots. I have a few more- though i'm not quite sure what you would like to see?
                    • #25
                      how much grinding and smoothing went into that rocker cover........
                      and you deserve the comments....You have put a lot in that car and it is an inspiration to me at least....
                      Craig....
                      1993 Ford Festiva
                      Under going Surgery
                      http://www.cardomain.com/ride/3097069
                      • #26
                        mick thats so sharp it almost makes me want to fix up the egg instead of the festy. . .
                        92 GL - parts car
                        97 aspire - parts car
                        87 323 DX - daily driver
                        • #27
                          that is AMAZING Mick!!!!!!!!!!!!
                          ~Nate
                          Current cars:
                          FOTY 2008 winner!
                          • #28
                            DAMN ... lotta blood sweat and mooola went into that Mick .. top work! Any performance figures --- Dyno / 1/4 mile ? Thats the B5 1.5L right ?
                            • #29
                              Sorry for the late reply.
                              Yes B5. (16 valve head). Has not been reg'd so no 1/4 times as yet.
                              • #30
                                WOW! Talk about sano! That is breathtaking what you have done!
                                Michael
                                Have owned 9 so far
