Power window upgrade
How lazy can you get? Push the button and the windows automatically go up. Great for a surprise cloudburst, I guess. This is an add-on module, to be used in conjunction with a power door lock/alarm system. Good thing there is room for both modules on a CPU mounting plate. How much was shipping again?Last edited by bravekozak; 05-10-2014, 06:39 AM.
These look identical to the ones I paid 22.86 and 14.86 plus shipping for.
http://www.aliexpress.com/item/Free-Shipping-KIA-Power-window-switch-KIA-Pride-double-window-switch-KK12B-66350-SCP/1002445438.html
http://www.aliexpress.com/item/Free-Shipping-12v-switch-power-window-switch-for-Kia-pride-KK12B-66-370-Button-switch-power/1050117929.html
Maybe they can get a right side armrest for me.Last edited by 1990new; 04-18-2014, 04:52 PM.
The fuse block terminal picture is in post #56 of this thread. Just hover until you see the underline and then click. The link used to be highlighted before the system upgrade. It's a real pain to open the crimped tangs again, but since you only need two (a large and a medium), it's worth not having to worry about a future short.Last edited by bravekozak; 03-29-2014, 07:26 PM.
Cool.. That looks pretty straight forward.
Sent from the depths of hell.
Just cut a piece big thick 8 gauge white wire from a junk yard car ( going into the fuse block). Splice it in to your white wire just ahead of where the harness branch goes to the fuse block. Crimp a recycled single terminal from a junkyard fuse block on the new white wire (hot in run) and pop it into an empty slot in the fuse block.
Crimp another recycled smaller single terminal from the junkyard onto a 14 gauge red wire and route that to your power window switch (or to your power window relay). The power windows share a common ground.
Again, here is my splice before I wrapped it in tape.
The wires that join the passenger window to the master driver armrest switch can simply be terminated exactly where the power mirror connectors are on both sides. Then they can be popped into female connectors.
I complicated the install by combining my power mirror, power window, power lock and door speaker wires all together in a single 13 position connector. My 14 gauge power window wires were light blue for up and light yellow for down. You can see them in the picture. The 14 gauge red and dark green wires are standard Mazda colors for power lock actuators.
Note: All crimps including fuse block terminals and splices are open barrel. 30 amp green fuse from junkyard.
I will post a pic of a salvaged fuse block terminal tomorrow.Last edited by bravekozak; 03-23-2014, 08:26 PM.
Nice.. Could a write up be in order for adding new circuits to the fusebox? Or is it fairly straight forward.
The Kia fuse block has different mounts than the Festiva fuse block. I didn't use it. Since I could not find new fuse block terminals, I recycled a couple of terminals from a junkyard Festiva fuse block. It took about five minutes to open up each terminal for reuse.
I added in two extra circuits. One for power windows and one for power locks. Only problem is, I didn't label them yet. It's easy to figure out which one is which. Just pull a fuse and see which one doesn't work. Both circuits are 30A and they work perfectly. There is no chance of a short which could cause a fire.Last edited by bravekozak; 03-22-2014, 08:14 PM.
How did the swap over go? Was it as easy as switching over the wiring and fuse linkages into the new housing and connecting the new appliances in?Originally posted by bravekozak View PostI am practising to swap in a Kia Pride fuse block.
It has the extra circuits for power windows, power locks and power antenna.
Sent from the depths of hell.Last edited by jawbraeka; 03-22-2014, 12:42 AM.
Is there a mention of rear windows, me having the 4 door model, I may as well do the lot on one go and those prices there are very nice.Originally posted by bravekozak View PostKKY0158605 CHANNEL-GLASS RUN RH $10.29 KKY0159605 CHANNEL-GLASS RUN LH $10.29
MS08458502 GROMMET-SCREW $0.48
Just curious also, do they happen to come in different colours?
sent from the depths of hell.Last edited by jawbraeka; 02-03-2014, 04:36 PM.
KKY0158605 CHANNEL-GLASS RUN RH $10.29 KKY0159605 CHANNEL-GLASS RUN LH $10.29 MS08458502 GROMMET-SCREW $0.48
Jaw this is for the three door Pride, and not the 5 door. Flocked black rubber for the channel runs and white nylon for the glass grommets. You need 2 grommets per window glass.
I don't know what the four part numbers are for the four belt moldings. I never bought them them from Four Green.Last edited by bravekozak; 02-03-2014, 04:42 PM.
Please let us know how much they are for the fronts and the rear as I wouldn't mind doing mine.Originally posted by Pu241 View PostBrave,
".....Glass channel run moldings and glass regulator grommets.
Doing so, will make the windows go up and down smoothly with very little friction."
You got FourGreen numbers on that for the next group buy?
I got a bunch of litte things I need to get.
Brave,
I would just like to add some information for all those wishing to perform their own power window installation.
You should also consider replacing your belt moldings, glass channel run moldings and glass regulator grommets.
Be careful on the door harness you order. The easiest install would be to have the switches in the console. The connectors are the standard .250" four position ones. If you choose to go for the long armrest install, the connectors are 9 and 7 position .090", respectively.
The door wiring harness would have to have the switch wires in addition to the motor wiring if you go the switch in the armrest route.
Either way, I can't over emphasize the use of open barrel terminals for a neat and safe install.
The console switches are each dedicated to a separate window.
The driver's armrest switch controls both windows (no lockout).
If you want lockout, you will have to wire a separate switch.Last edited by bravekozak; 02-03-2014, 11:11 AM.
This sounds great.. There are a few of those things I'd like to see like power antenna, power windows, power locks.. The mirrors would also be a nice edition too.Originally posted by bravekozak View PostEven though I have new grommets for the door window glass, the windows struggle to close near the top. Today, I finally found my bottle of Chemplast fluoro glide 200 dry lubricant (powdered teflon). I checked on eBay and only found this one. It is very expensive, but worth it. Far superior to baby powder in the window rubbers.
Yesterday evening, I also figured out how to downgrade AVCHD m2ts video files to mp4 for YouTube. Next spring, I will post a video of the windows in action, as well as power antenna, power locks, lighted vanity visors and twin carb teamwork.
In regards to the silicone drops/liquid, try a local electronics shop. They sometimes have silicone spray and at a rather inexpensive price.
sent from the depths of hell.Last edited by jawbraeka; 12-14-2013, 10:25 AM.
