That Suzuki Esteem at the junk yard had mirror mounts very similar to the Festiva. I brought them home and found that the hole spacing on the main mount was identical to the Festiva. Unfortunately, they did not have as much of an angle as the Festiva visors. They hit the mirror. Too bad though. They had mirrors in them and they telescoped on the arm. See for yourself.
visors too wide!
Remove the festiva mirror, and get a universal one that you can mount on the windshield... Possible? Those would be nice to have if that would work.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
solid core
They are made of a solid core material. The stock Festiva visor is made of some kind of fiber and tends to break apart and go mushy with handling.
I am still searching for a lighted vanity mirror combo that fits. I am still waiting for a Mini cooper to show up.
Maybe an old Corvette or Volkswagen mirror that mounts on the dash would do the trick?
Aspire mirrors are pretty good substitutes, and you can use the hook thing that comes with it if you drill a hole. The Aspire mirrors cover more of the area in the middle, whereas the Festy ones just leave that open to the sun.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
is the area to the right of the mirror solid or plyable? I may be able to modify them.
the Festy ones are a solid wire all the way around sanwiched between tow peices of foam covered in vinyl
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
solid
They are solid. It appears to be foam in place with a very dense urethane.
The covers are not removable. I got another set the other day out of a different car. The passenger side had a mirror the drivers had a storage loop for receipts, etc. The out side was smooth and the inside was a little fuzzy.
Even though they had the same backcut the Festiva has, they were too wide.
mini visors
The mini visors are the right size. However, the mounting flange is larger and oriented on an angle for the "A" pillar. Which means, that there is lots of work to be done to adapt them.
I have decided to let the visors hit the rear view mirror.
Too much work to peel off the vinyl, cut out the metal track from a Spectra visor, shorten it, implant it in the Mini visor, then have leather covers stiched back on$$$.
I start by discarding the AMP/Tyco electrical connector and snapping off the plastic mount. As you can see it is tapered and was essentially a one way install and snapped into place for a tight swivel.
Next thread, I hope to drill out the metal rods from the Festiva mounts and prepare to install them. The Mini visors light up beautifully. I have to make them work.Last edited by bravekozak; 03-24-2010, 05:17 PM.
dimensions
The Festiva sun visor rod is exactly 8mm diameter. The rod end is straight and relies on friction to not come off. I had to use a pin punch to get it out of the plastic mount.
The Mini cooper rod end on the other hand is tapered. Great news. It tapers from 9.64 to 9.1 mm over a distance of 10.44 mm
A combination of taper pin reamers will be necessary to cut the plastic out.
First a #6 taper pin reamer, followed by a #7.
The Festiva mirror mount shank is deeper than the Mini. I will first have to cut about .4" off the Festiva mount
Since the mount must snap down over an 8.6mm end, I will also have to make two kerf cuts perpendicular to each other on the end.
Next post will let you know if I the surgery was successful.
Originally posted by TominMO View PostAspire mirrors are pretty good substitutes, and you can use the hook thing that comes with it if you drill a hole. The Aspire mirrors cover more of the area in the middle, whereas the Festy ones just leave that open to the sun.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
too much of an angle
There is too much of an angle to heat and bend. So, I started with a #6 spiral flute taper pin reamer. It was new and cut the plastic just like butter. The base of the hole must be .387". It can only be done with a #7 reamer.
Two reamers have to be used because the original hole was straight and not tapered like the mini arm.
The goal is to have lighted vanity mirrors in my Festiva.
