Originally posted by FB71
EGT seats & console
well, I won't make that claim. I'm sure someone did it before me, too.
I did basically the same thing. I modified the Prelude seat foam to fit the Festiva frame. Then, I cut up the Prelude material and restiched it to fit the modified foam. I still have the seats; they're in storage at the moment, waiting for Project Snot to restart (as soon as the house remodel is done... priorities, you know!)Jim DeAngelis
Nope, not very hard.....................time consuming thoOriginally posted by bravekozak View PostI never even considered an Escort. That is a job well done. That is a lot of hard work. I'll keep an eye out for some more beige push pins for you. Super.
The hardest part was cutting the foam so it fit the Festy seat properly.then it was a matter of measuring the seat cover and cutting and sewing it to fit the foam.
Current
Retired
4 inches - so two inches off each inside of the split? and four of the center of the base?Originally posted by ToSloTrk View PostThe escort seat is approx. 4" wider than the Festy seat.
I don't know about keeping the split, if you use the non-split seat you could cut the foam to fit the Festy frame and then cut the Escort seat and re-sew it to the width you need.doing this would def be easier than trying to keep the split
whats the width of the splits before you started hacking? is it even worth it to keep the split off centered like that?
ybnrml - that bar can be fabricated
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
I didn't take anything off the seat bottom just streched it over the Festy foam & frameOriginally posted by Festiva_tunner View Post4 inches - so two inches off each inside of the split? and four of the center of the base? ?
I took some rough measurments:Originally posted by Festiva_tunner View Postwhats the width of the splits before you started hacking?
Festy seat each half is roughly 18 1/2"
Escort seat measures roughly 25" & 15"
so I took approx.6 1/2" off one side and added 3 1/2 to the other side.
Originally posted by Festiva_tunner View Postis it even worth it to keep the split off centered like that?
I would think that trying to keep the split wouldn't be easy as you need to use the Festy frames.(the seatback latches are to low on the Escort frames)
Current
Retired
update on map pockets
Escort map pockets one is cut and has trim to match seats the other is the bare Escort pocket
just showing what I cut off of the pocket. I used the door panel to try and get the radius close
showing the back side of the pockets.I just measured the hole placement and drilled for the mounting screws
old vs new...........I'll likely paint it to match the door panels
Current
Retired
I'm not saying it would be easy I'm just thinking less foam to cut and relocate - hear me out -Originally posted by ToSloTrk View PostI didn't take anything off the seat bottom just streched it over the Festy foam & frame
Measure out and cut off the 3 inches you removed from where the escort seat splits - mock up on the non-split rear frame with out any foam on it - then custom make a bracket for each side of the split - simply remove the original frame between the newly created brackets - trim the fabric to fit the newly created 40-60 frame??? you think that would work? You have more insite on this since I've never actually had the rear seat frame apart
I think it will look good with the paint to matchOriginally posted by ToSloTrk View Postold vs new...........I'll likely paint it to match the door panels
92 GL - parts car
Ok.... I think I understand now....you are thinking of making a split seat out of a non-split seat.Originally posted by Festiva_tunner View PostI'm not saying it would be easy I'm just thinking less foam to cut and relocate - hear me out -
I don't know why it wouldn't work but I've never had the seat cover off a non-split seat. I would think if you have a welder and a bit of tubing to use for the frame where you make the split it should work.:thumbleft:
Current
Retired
Bingo now your cooking with large explosivesOriginally posted by ToSloTrk View PostOk.... I think I understand now....you are thinking of making a split seat out of a non-split seat.
92 GL - parts car
door handles & map pocket
painted the map pocket to match the door panel.............
grabbed the Escort door handles and found they use the same spacing for the mounting holes.
the Escort handles are much more comfortable as they are padded.
Current
Retired
Looks awesome - might have to grab a set myself
92 GL - parts car
I have some EGT door cards......Hmmmm-Greg
Redneck Engineer
FOTY - '09
