Power...
Originally posted by resuwrecked View PostLol
Any lock actuator can be made to work as long as it fits, line of pull lines up with the lock linkage, and can be mounted properly. any car with power door locks or anything can be robbed of its actuators.
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
You could probably disconnect the lock and the outside handle and just use this exclusively to open the hatch. I mean with this it could eliminate the need for either honestly.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Originally posted by MONSOON View PostYou could probably disconnect the lock and the outside handle and just use this exclusively to open the hatch. I mean with this it could eliminate the need for either honestly.
92 GL - parts car
Thats what Im saying, instead of hooking it to the lock. Disconnect the lock and handle rods and have the actuator conected to the handle rod. You dont have to worry about someone opening an unlocked hatch because the handle isnt functional anymore. The actuator is doing its job now.Last edited by MONSOON; 03-07-2010, 09:25 AM.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
I see now - not sure there's enough room to mount it in the up position there though but that would work
92 GL - parts car
Originally posted by bravekozak View PostIt was so nice today, I decided to take a stroll through the junk yard. I found another MPV. This time I took out the actuator in less than two minutes. Mr. Tunner, are you coming to Ohiostiva? I could bring the one in the photos for you.
92 GL - parts car
figured it out
There are two wires, a green and a red. When green is negative and red is positive, the arm goes out, when current flows the opposite way, the arm pulls in. So the solenoid, unlocks or locks only. It does not pop the hatch. That task is reserved for your five fingers.
I'll keep my eyes open for a lock cam with two rod holes.Last edited by bravekozak; 03-09-2010, 08:27 PM.
Why do you need it to pop the lock and open the hatch? Are you removing your hatch handle? The hatch handle rod and the lock rod are perpendicular to each other so a single actuator making a single pull or push motion can't actuate both.
Are you looking for a lock cam with two holes so you dont have to clamp it like I did? that would be a cleaner install, and would also require a different mounting situation.
Originally posted by bravekozak View PostThere are two wires, a green and a red. When green is negative and red is positive, the arm goes out, when current flows the opposite way, the arm pulls in. So the solenoid, unlocks or locks only. It does not pop the hatch. That task is reserved for your five fingers.
92 GL - parts car
I'll keep my eyes open for a lock cam with two rod holes.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
