just purchased spoiler & i am noy sure how high to mount it & if i just use selftappers & also the correct way to install the plugs. tks
spoiler install
I don't know the height but I would recommend marking it out and drilling the proper pilot holes for the screws you are using and then installing the screws and spoiler with a SCREWDRIVER so you don't either strip the metal out and not hold it tight, or get it too tight and crack the spoiler.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
thanks!Originally posted by Nerd Racing View PostI don't know the height but I would recommend marking it out and drilling the proper pilot holes for the screws you are using and then installing the screws and spoiler with a SCREWDRIVER so you don't either strip the metal out and not hold it tight, or get it too tight and crack the spoiler.Never Hire a Boy to do a Man's Job!!
This is what I did and it worked fine. I then filled the holes with that non-hardening window glaze, to prevent water from getting in; then put on the caps. Install it more towards the rear, not the front of the hatch top; otherwise when you open the hatch, the spoiler front edge will contact the roof.Originally posted by Nerd Racing View PostI don't know the height but I would recommend marking it out and drilling the proper pilot holes for the screws you are using and then installing the screws and spoiler with a SCREWDRIVER so you don't either strip the metal out and not hold it tight, or get it too tight and crack the spoiler.Last edited by TominMO; 11-05-2010, 11:45 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
thanks for the pointers! glad you mentioned to watch the opening!! the window glaze lowes carry it?Originally posted by TominMO View PostThis is what I did and it worked fine. I then filled the holes with that non-hardening window glaze, to prevent water from getting in; then put on the caps. Install it more towards the rear, not the front of the hatch top; otherwise when you open the hatch, the spoiler front edge will contact the roof.Never Hire a Boy to do a Man's Job!!
You can see where the factory holes for the plastic grommets are in this pic of my hatches.Last edited by bravekozak; 11-05-2010, 01:06 PM.
Junespeed said 3M double sided foam tape would be fine. They are cosmetic. Any downforce is probably VERY minimal.Any difference that makes no difference is no difference.
Are the spoilers from Junspeed as heavy as the stock ones?Originally posted by sketchman View PostJunespeed said 3M double sided foam tape would be fine. They are cosmetic. Any downforce is probably VERY minimal."Blue92"- 92L 5 spd, original owner- 185K, B8,DD..
"Wenona"-89L parts car
Now that IDK. Never had a stock one. Are they heavy?Originally posted by jawja jim View PostAre the spoilers from Junspeed as heavy as the stock ones?Any difference that makes no difference is no difference.
Here is an Excellent Spoiler Install How to! I know, because I wrote it!
http://www.fordfestiva.com/forums/sh...to-quot-(pics)Dan
