thanks again, if i come across another one at the yard i will pick it up and do a couple other things including the filling in of the oval part
93 grill mod....
on thing that would look pretty cool is if you found an LED ford emblem to put on the filled in part of the grille. heck even it would look good behind the mesh of one of the late 80s festys with the factory ford emblem removed. so that way you have a cleaner look and when it gets dark just flip the switch and you have a custom emblem shining from behind the mesh
Don't forget the flat metal, Studebaker Avanti look
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
yes thats a clean look but it would not have worked with the festiva i had because of its cooling troubles. mine would get pretty hot so i wound up putting a functional hoodscoop on the car and never had cooling troubles again. i even put the same mesh in it that i molded to fit in the grilleOriginally posted by BigElCat View Post[ATTACH]5318[/ATTACH]
