I think it looks good! Can't wait to see it painted.
93 grill mod....
safety guy, it definatly got easier as i went, not really a problem with the fiberglass just the fact i bought spot putty, it dries in like a year it seams, but i got most of it filled, just going to get some body putty to finish up
thanks to both for the comment, im going to be getting some mesh before long03 Chevy S-10 Extreme-4.3
92 Ford Festiva GL-to be determined
92 Buick Roadmaster Estate Wagon-5.7
i had the same grill on my 90 festy but i did a different mod to it and it turned out pretty well. i took that stainless gutter mesh and molded it to the inside of the grill and bonded it to the inside of it with construction cement. heres a couple pics of what it did.
Got any front pics with the new grill and mesh?Raising the bar for compact cars around the world.
.:: 1997 Aspire ::. The Glowspire. Revived project
.:: 1998 Aspire ::. The Glowspire red bean. Current Project
My Ford Aspire DIY Wing Conversion
Glow_Mouse's 97' Glowspire
Glow_Mouse's 98' Glowspire
Ford Aspire Forum Here!
Order FordAspire.com Decals Range 1!
Order FordAspire.com Decals Range 2!
i Spy a super nintendo controller :p
Lmcclure, It's looking good though! I think it would look really cool with a mesh behind that, maybe the chrome "Festiva" emblem on it to fill some of the empty space, on the far left or right.Last edited by Charlie1717; 07-03-2011, 10:43 PM.-------------------------------------------------------------------------------------------
My Musica! Click me!
^x2 you can get the chrome "Festiva" emblem on eBay for like seven bucks1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
you do indeed charlie1717, who needs black opps when you have mario? this guy...lol
i dont know if anyone seen this pic but charlie, mcnasty this was takin at the begining of the project
this is what i used for the mesh in the grille. i just took the grill off the car and cut out the shape of the inside the grill shape with about an inch and a half extra material around the grill shape and marked in the mesh where the grill shape was and molded the mesh around that shape. once i got it where it needed to be then i attached it the back side of the grill with heavy duty construction adhesive and let it set til it was rock solid.
most hardware stores have these gutter covers in sets but should have them in singles as well. i got mine at ace hardware for $3 but where you are and what store you get it at also makes the price very a bit.Last edited by festy90; 07-07-2011, 12:52 PM.
yeah i think the mesh would look awesome with the modded grille and the festiva emblem embedded in it somehow. the emblem should be fairly simple to attach since most emblems iv seen that arent the adhesive type have fasteners that hold them on. if its the fastener type then you can just fasten it thru the mesh but if its the adhesive kind them im not real sure right off hand how to attach it.Originally posted by Lmcclure View Postyou do indeed charlie1717, who needs black opps when you have mario? this guy...lol
http://i167.photobucket.com/albums/u...a/100_0610.jpg
something else that would look good would be some LEDs mounted behind the grille so the light from them highlight the mesh and everything else.
you are the man festy 90, i went to sutherlands since it was a little closer, found the mesh, i made a mistake on chopping off the mounting pins on the back of the festiva emblem so i will be using double sided sticky to try and keep it attached, and i did the same as you with the cutting out and folding over....and to the pictures everyone wants..
enjoy
Good job! That mesh does look nice. I didn't think I'd like it that much, but I do. Of course, my tastes run towards flat black trim. If I do mesh, it'll probably be blackened.
However, your silver mesh will show up better and have more "visual" impact.
