FestivaReeds HID Conversion! (caution pic heavy)
  • #16
    well we will see how it turns out, this is pretty much a fun project for me and i have a unlimited supply of broken headlights from work, so ill tinker and tinker and find something that works for me , and considering im a PA state inspection mechanic , i have a very good understanding of PASS/FAIL headlights. either way im having fun with this and im determined to make something work !
    Check out my HID Conversion in progress!
    • #17
      Go for it!
      Maybe you can come up with something that works really well and it fairly easy to install.
      ~Austin
      Red 88 L (Ocho)
      • #18
        waiting on new bulbs to come in should have them by wednesday
        • #19
          FestivaReed, they sell crystal clear Pride headlights on Alibaba.com that have the reflectors you're looking for.
          • #20
            yea, not trying to buy 24
            • #21
              Aww, come on! Think about how bright it'd be!
              • #22
                Might need to grab a bigger alternator, maybe the dual setup out of an ambulance...
                Owner of:
                1991 Red Festiva L, 5 speed (Swagger Wagon)
                In progress:
                BP+G25MR swap, Kia rio axles hopefully.
                • #23
                  ^^ lol
                  Walth
                  Festiva #1: 91 Red L 4/5
                  http://www.fordfestiva.com/forums/sh...ad.php?t=27981
                  • #24
                    Originally posted by GenevaDirt View Post
                    all you are going to accomplish is blinding people as you drive....you could have saved all the hassle and just bought a plug and play kit from ebay.
                    Agree x100... And even with a plug and play kit, you're still going to blind everyone. If you want to do HID's, then do a retrofit and do it CORRECTLY. I've yet to see someone do it in the Festiva with the stock headlights... Someone did one in a custom headlight, but I can't remember if he ever finished them or not.
                    If your cutoff doesn't look like this, then you're doing it wrong (granted, it's a little high in this picture - I adjusted it down correctly after this shot):
                    Simon - pimptiva.com
                    • #25
                      nice
                      Walth
                      • #26
                        im not using projectors, look the STOCK headlight i took apart, did not use a projector lens or anything, it used a center diffuser, a clear non magnified outer lens and a diamond cut non magnifying pattern cut into the back, thus is why im trying to retro fit this and i have all the time to do it, so i will make it right , sooo to all you nay sayers !
                        • #27
                          got my bulbs in today , after i lay some sound deadener ill get some new pics up
                          • #28
                            UPDATE :
                            New plan! . i happen to get a set of nissan maxima headlights without the ballasts, so i took them apart and whaaats this? HID with high beam flapper built in !!!! so i wired everything up and hmmm lows turn on the hid , and highs kick the flapper but turn my bulbs off....hmmm highdea! out a SPST (single pull single throw) relay in and boom! lows work and highs activate the flapper and light stays on! pics when its dark! , only 2 steps left with this HID project, use the spare 12v hot feed in my relay to feed a smaller relay connected to a rx7 factory fog switch connected to the fog lamps in the Maxima headlight unit so that when i turn the fog lights on they will come on but since the relay i used for my HIDs turns power off to the fogs when the high beam circuit is turned on !....anyways off on a tangent
                            ... next is to cut the rear of the stock housing to fit the HID unit , and either find someone who has a clear lens for the housing or , possibly take the glass to somewhere that can make/sand the glass clear
                            • #29
                              BREATHE! Then pics!
                              • #30
                                hahahaha
