well we will see how it turns out, this is pretty much a fun project for me and i have a unlimited supply of broken headlights from work, so ill tinker and tinker and find something that works for me , and considering im a PA state inspection mechanic , i have a very good understanding of PASS/FAIL headlights. either way im having fun with this and im determined to make something work !
FestivaReeds HID Conversion! (caution pic heavy)
FestivaReed, they sell crystal clear Pride headlights on Alibaba.com that have the reflectors you're looking for.In love with a MadScientist!:thumbright:
Originally posted by FestivaReed View Postyea, not trying to buy 24In love with a MadScientist!:thumbright:
Originally posted by GenevaDirt View Postall you are going to accomplish is blinding people as you drive....you could have saved all the hassle and just bought a plug and play kit from ebay.
If your cutoff doesn't look like this, then you're doing it wrong (granted, it's a little high in this picture - I adjusted it down correctly after this shot):
Simon - pimptiva.com
im not using projectors, look the STOCK headlight i took apart, did not use a projector lens or anything, it used a center diffuser, a clear non magnified outer lens and a diamond cut non magnifying pattern cut into the back, thus is why im trying to retro fit this and i have all the time to do it, so i will make it right , sooo to all you nay sayers !Check out my HID Conversion in progress!
got my bulbs in today , after i lay some sound deadener ill get some new pics upCheck out my HID Conversion in progress!
UPDATE :
New plan! . i happen to get a set of nissan maxima headlights without the ballasts, so i took them apart and whaaats this? HID with high beam flapper built in !!!! so i wired everything up and hmmm lows turn on the hid , and highs kick the flapper but turn my bulbs off....hmmm highdea! out a SPST (single pull single throw) relay in and boom! lows work and highs activate the flapper and light stays on! pics when its dark! , only 2 steps left with this HID project, use the spare 12v hot feed in my relay to feed a smaller relay connected to a rx7 factory fog switch connected to the fog lamps in the Maxima headlight unit so that when i turn the fog lights on they will come on but since the relay i used for my HIDs turns power off to the fogs when the high beam circuit is turned on !....anyways off on a tangent
... next is to cut the rear of the stock housing to fit the HID unit , and either find someone who has a clear lens for the housing or , possibly take the glass to somewhere that can make/sand the glass clearCheck out my HID Conversion in progress!
Originally posted by FestivaReed View Postuse the spare 12v hot feed in my relay to feed a smaller relay connected to a rx7 factory fog switch connected to the fog lamps in the Maxima headlight unit so that when i turn the fog lights on they will come on but since the relay i used for my HIDs turns power off to the fogs when the high beam circuit is turned onIn love with a MadScientist!:thumbright:
hahahahaTrees aren't kind to me...
