here are parts still available at 4GREEN that isn't a perfect "bolt in" conversion but should be doable with common tools and sense. unfortunately, pride belts for the 2 DOOR are no longer available. but these for the 4 DOOR are. the center buckle stalks are the same for both. this is correct for the LHD with "belt buckled" sensor on the drivers stalk. the center stalk section is a direct bolt in for the existing holes in the festiva floor. the stalks are about an inch shorter than the festiva stalks. shouldn't be a problem. the KIA stalks will NOT accept the male end of a festiva belt which is just slightly wider than the KIA so you almost have to buy the whole set up. amazingly though, all these pieces are under a $100 before shipping.
the end of the belt that bolts into the floor through the carpet is EXACTLY the same as the manual festiva end but as the picture shows, the mounting at the spool end will need some modification. you'll probably have to bend and redrill the KIA bracket to fit the festiva mounting position. then just find a set of A and B pillar trims and your golden.
part# LH BELT - KK153 57 690E 04 / RH BELT - KK 153 57 630D 04 / CENTER STALK - KK136 57 620B 09 / REAR CONSOLE - KKY01 64 411 09 / BELT CLIPS - KKY01 57 985. also just to mention, the grey color of the KIA belts is a little lighter than the festiva grey belts so they won't match the stock back festiva belts but the plastic mounts and buckles is dead on.
