Ok i did a little research today, i plan on using the capri brakes and capri wheels. and from what i see i might need to use the capri strut/springs. no real problems other than the 4 bolt mount(no pictures)
When i took the driver side wheels off both cars(currently driving the Capri) i noticed a pretty big difference in the spring perch on the struts, and the clearance between the pearch and hub.
Capri
Festiva
The Wheels DO FIT. but im pretty sure there will be a lot of rubbing.
Capri wheels on Stock festy with KYBs
and from what i can tell. the front hub and disks will bolt up.
Capri
Festiva
MUCH BIGGER BRAKES!
And this is just for you to see my messed up door and bigger rims on the festy.
i never set the festiva on the ground with the rims on. i was jsut getting some measurements and jsut seeign how the fitting was going to be.
And i just picked up this.
Capri
Festiva
Capri
Festiva
MUCH BIGGER BRAKES!
