and as long as its based around the stock festy upper mount it should work with many spring/strut combos, right? im buying teins (which use the stock upper rubber mount) and would be very interested in a set of camber plates to add to my setup. the others who went in on the group buy (i have 2 others) might be interested as well.
Camber Plates Please: To the Phillipiens
I should think a camber plate for Festivas would also work on Aspires and '01 & most '02 Rios. I think all these cars have essentially the same strut mount dimensions.
Not far from where I work there is a laser cutting place that I'm sure could easily cut out some camber plates if you made up a drawing with dimensions, even if it's hand drawn, I can give the measurements to my boss and he can make it up a CAD drawing to send to the laser cutters to have them made up and I can ship them out, just an option for ya
The prices would be fairly cheap, once the CAD drawing is done (which my boss would do for free) the laser cutters just cut it out following the CAD drawing, and their rates are pretty reasonable I believe
i made some.... easy to make, i cut them out with a jig saw lol... if someone has a flowjet they could make them for real cheap...
Mike, AKA the sasquatch
Originally posted by Gforcefd View PostSasquatch what did you use for a bearing so they don't bind? And what top hat is on the springs? Look great, would love a set like that if you have dimensions or anything.
Logan
Originally posted by Hot_Wheels View PostHey chris i asked fred a while ago he drew one up in cad, he said he would draw another one up he just needed some dimensions of the top hat mount, have you talked to fred lately?
Hey Mike, those are really simple looking. I didn't know you could go without using the strut mounts, though. No binding issues?
Okay, thinking about it:
When the knuckles turn, the strut rod turns inside the strut body, right? Would this produce undue wear inside the strut itself, creating sealing issues or reducing longevity?
I have no idea, but the thought of dropping the weight of the strut mounts is certainly enticing. It would give a firmer ride, getting rid of the rubber isolating material in the mounts, though.
KarlLast edited by Safety Guy; 01-07-2011, 10:13 AM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
Originally posted by muscle_Car1 View PostCucso made some. Right ricky
