Originally posted by getnpsi
26 spline hub?
The Festiva Store
Originally posted by nonamekid View PostThat is correct. They use the BG chassis. The Protege, Escort, and the MX-3 all use the same chassis.
Yeah but the mx3 is different than the rest of the BG chassis. So is the 1995-1997 kia sephia technically.It's a good thing you don't read the stickies, you might of learned something.
Poverty produces creativity
The protege is different than the escort and the 323, yet they are still all BG chassis. What are you referring to in particular. The axles and transmissions and engines all swap between them. All the cars have been slightly tweaked from the basic chassis.The Festiva Store
I went to the junkyard today, and there was an Escort GT and a Festiva sitting side by side. I eyed up both knuckles and they do look awfully close to fitting. Close enough to give it a try. The escorts look slightly taller, but I may be able to compensate with my coilovers. I will go back when it's not raining and get the GT Knuckles, brakes, and calipers, etc. And try to convert to work with my festiva.'93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
^let us know how that goes...
Mike, AKA the sasquatch
