Aspire brake swap question
  • #31
    Well, might not get oldest post award, but I tryin. I was taught if you need to bleed brakes and don't have a helper, get a flexible tube that just fits over the bleeder zerk. Loosen the zerk, stick the tube on it and stick the other end in a new can of brake fluid. pump pump pump and keep the MC reservoir filled up. Tighten zerk. Move to next wheel. Does everybody do it this way?
    qroger
    • #32
      i don't use new fluid, i let it gravity bleed into an empty container unil the hose end is covered and then start pumping (slow in, fast out)
      • #33
        which is the better way to go with aspire swap ?....auto or manual ?...i understand the auto brakes are heavier ?...true ?
        1992 festy GL, loaded, stock, 79 K
        1994 Ford ranger - 2.3 I4 - 5 spd.
        1999 Ford ranger - 3.0L V6 - 365 K and rising ! ( shooting for 500 K )
        2000 Ford F-350 dually crew cab - 4x4 powerstroke !
        2003 Ford Focus SVT - supercharged
        2005 Saleen N20 Focus
        " If it hurts when you do that, Dont do that !!! " - mikec
        " Age and treachery will always overcome youth and skill ! " - unknown
        " Three can keep a secret, if two are dead ! " - Carlos Marcello
        • #34
          The auto aspire rotors are thicker and vented.
          • #35
            hmmm...wonder if vented would be better than non vented or get the solid ones with slots/holes in them ( aftermarket ) ?
            • #36
              wonder about weight difference between auto and manual cars ?
              • #37
                I just bought those one for my aspire swap:
                • #38
                  those look pretty good...hmmm...drilled, vented ...i like that...shipping will be cheaper for you too...seems like a pretty cheap price thou....let us know what you think of them after you receive.....
                  • #39
                    i drove an aspire swaped festy that had vented/drilled/sloted rotors, it didn't stop nearly as hard as my capri swap and it was harder to modulate the pedal. just my personal experiance.
