Just bought this festiva for the kids to drive on the farm. 1989 model, 4sp manual, 25" atv tires. the top is cut off and they were using it as a poor mans mule. it goes great, but need stiffer suspension. any cheap mods to improve the suspension and possibly get a little more ground clearance. any help would be greatly appreciated. thanks for the great site.
off road suspension upgrades?
Ford aspire suspension will raise your ride height and be a little stiffer. And welcome to the site. It's the best forum around.
Way to start too. We like picsThat thing is so cool. And add your location.
Redneck Engineer
FOTY - '09
Easiest and cheapest idea would be to put in the aspire front sway bar. You can also create a home made rear sway bar that works really well. Here is a link to that info:
Those are your 2 best bets for cheap and effective ideas. Good luck!Last edited by timmay89; 04-06-2010, 11:59 PM.
Has anybody tried the rubber or urethane spacers that go between the coils. I think the swaybar would limit flex to much. Not concerned about handling at anything over 15-20 mph. The tires are 25-8-12 on the front and 25-10-12 on back. They are the stock rims, reversed on the back so the tires wouldn't rub. The fenders have been cut out flush with the inner. The front tires rub a little if you cut it hard. It pulls good, but i'd like to find a way to gear it down. The kids have been having a blast with it and they are learning to drive a real car. Thanks
Originally posted by jge3 View PostIt pulls good, but i'd like to find a way to gear it down.
BTW, Welcome to the site.Last edited by JPT; 04-07-2010, 10:15 AM.Festiva: Because even my dog can build a Honda.
I believe the earlier Aspire transaxles would have the lowest final drive ratio. IIRC, in '96 and '97 they went up a bit for better fuel economy.
Kia Rio struts are a direct bolt-in and have thicker springs than the Aspire. Years '01 and most of '02. I think 1.5s from '03 might work, but the 1.6s and later models used a different three bolt strut mount. Here's more info:
For the rear? Try using front Festiva or Aspire springs with the rear shocks. I think someone said it would work, but I'm not sure.
KarlLast edited by Safety Guy; 04-07-2010, 12:33 PM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
thats a kewl one.... wish ihad a couple of those they look fun!IF ONE FESTI IS GOOD THEN TWO IS BETTER!
93 L TEAL ( this winter new paint) full 2.25" exaust w/flowmaster 2 chamber! all black interoir! coil overs and aspire swap in the wings and 14" jetta mk3 alloy wheels! bp+t on the way!
Originally posted by Safety Guy View PostI believe the earlier Aspire transaxles would have the lowest final drive ratio. IIRC, in '96 and '97 they went up a bit for better fuel economy.Festiva: Because even my dog can build a Honda.
No, I don't know offhand. Someone posted them around here a while back.
I doubt the small gain in low end would be worth all the work swapping transaxles, unless you needed a new one anyway and had a choice.
Awesome work, Welcome to the site, I think You just inspired my next project "Jeepstiva" Here we go!!!1993 Ford Festiva GL "My Cream Puff & new project"
1998 Isuzu Rodeo
1994 Suzuki Intruder 1400cc "Da Cruiser"
1999 Chevy Silverado Z71 "My Work Horse"
1994 Isuzu Trooper "Camo Off Road Beast"
1989 Festiva L Stock Engine "Rallytiva71"
Daily Driver,Rally Racing Look,Little Additions Daily. *******Sold*******
FOTM October 09/ October Page FF.Com 2010 Calendar.
http://www.cardomain.com/ride/3810528
Originally posted by jdm babaganoosh View Postgrab some 4" caster wheels off a shopping cart and bolt them between the strut hat and the body.
you'll need to elongate the bolts, but it'll give you a 2" lift.
I think Hockey Pucks Will work too, I used to have them in my Toyota Pick up1993 Ford Festiva GL "My Cream Puff & new project"
1998 Isuzu Rodeo
