Installing new rear struts
  • #31
    I'm not sure if it was harmful or not but when I changed the struts on my festy the captured nut broke loose from the beam without knowing what else to do I cut the plate off of the and put wrench on the nut and got it off but before I put the strut back in I took my trusty mig welder and welded the nut back on better than factory and I welded the plate back on it has worked for me I now weld the nut before I do struts on my new cars and I have had no problems
    Justin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
    • #32
      ....thats actually a really good idea....
      alot easier than messin' with a spinning nut that ya cant get off without inventing new cuss words!
      .....'course I happen to have a welder too.
      Dan
      • #33
        I do it now before I do struts on all my new cars plus the heat from the welder that is directed to the nut helps the bolt break loose I still haven't found a fix for the bolt being stuck in the strut though
        • #34
          I have, you smother the bolts in anti-cease (auto zone $6.00 jar!) to the point when you're getting close to tight it's oozing out like a fat PB&J
          I also put a liberal amount into the threads pre-install as well.
          Walth
          Festiva #1: 91 Red L 4/5
          http://www.fordfestiva.com/forums/sh...ad.php?t=27981
