I have heard the aspire lower control arm is longer then the festiva but were is the differanace added, inside or outside the sway bar bushing??
aspire vs festiva control arm ??
I would think outside because people have hooked them up without issue as far as bolting them in.Originally posted by NovaSS View PostI have heard the aspire lower control arm is longer then the festiva but were is the differanace added, inside or outside the sway bar bushing??"FLTG4LIFE" @FINALLEVEL , "PBH"
Right, outside.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Outside is great. minigun has adjustable camber plates but I have to almost max them out toward the inside to get neutral camber, with longer lower control arms it would help me get a small amount of negative camber and center the camber plates. I guess Ill give them a try.money pit
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
cool....I hope they help"FLTG4LIFE" @FINALLEVEL , "PBH"
Good graphic depiction, Nate.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
ohhhh....they are opposite what I would have thought from all that have been installed by mistake.Originally posted by skeeters_keeper View Post
No prob!
I want to see 'er on the road already...
~Nate
Current cars:
FOTY 2008 winner!
festyfreak, if you do this w/ your stock axles they will pop out of the trany, and I'm pretty sure if you use the aspire axles they are still too long, so you'd need a custom axle.
iceracer I'm pretty sure they are the same on the BJ end... i could measure them if someone needs it.~Nate
Current cars:
FOTY 2008 winner!
I know there is a differance in the outer tie rod ends I think is one is tapered at 7 and the other at 10 degreesOriginally posted by iceracerdude View PostDo an inspection of the taper on the ball joint end. It seems to me I read somewhere, that may have a different angle as well. It would be good to find that out right now as well.money pit
^^correct.
Also, the ball joints are not tapered, so maybe you were thinking of rod ends iceracer?
Furthermore, I was just thinking, since everyone that does an aspire swap (including myself several times) uses festy LCA's in aspire knuckles with no issues they must be the same diameter. Its raining like crazy here so I haven't run out measured them but there isn't really any reason too; I'm sure they are the same.~Nate
Current cars:
FOTY 2008 winner!
