only reason to use aspire LCAs in a non-Aspire format is for the capri swap. al other swaps/mods use festy parts.
aspire vs festiva control arm ??
If my logic is correct, when doing a g series swap, one should be able to use egt axles and midshaft, aspire lca's and egt knuckles. This would give bigger brakes reduce the need for the coveted xr2 axles.
Let me know if I'm right.Neil
Jesus loves me. This I know.
93 L track prep in progress
88? Parts car-sold
86 b2000- pisses of HOA-sold
Yeah, I think you're right, that must have been what I read then not the ball joint endsOriginally posted by NovaSS View PostI know there is a differance in the outer tie rod ends I think is one is tapered at 7 and the other at 10 degrees
if you are right, i know what im doing in a bitOriginally posted by gorgonheimer View PostIf my logic is correct, when doing a g series swap, one should be able to use egt axles and midshaft, aspire lca's and egt knuckles. This would give bigger brakes reduce the need for the coveted xr2 axles.
323 gt axles are to hard and expensive to find around here
and i want to adapt those rx7 calipers i have been thinking about... they would look sweet and stop hard
Mike, AKA the sasquatch
ya if you use the aspire ones it puts the hub out about a 1/4 of an inch... and makes the axles pop out...Originally posted by muscle_Car1 View Postin the 5 swaps I've done i've allways used the stock festy control arms, and have never had an issue with them. I have heard of people having issues with the aspire ones.
but if you used longer axles (escort gt) them maybe you could make it work...
Poverty produces creativity
