Well after installing new front wheel bearings (for the 3rd time) I am eating them up. They lasted 3 days and now Ill be buying a new set. I have no idea whats going on. I know I have installed them correctly. Someone on here said something about a preload spacer? I looked around and couldn't find anything like that on autozones website. I never noticed this spacer the first time I replaced the bearings so I have no idea what im looking for.
Not again!!!
Not again!!!
89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.netTags: None
The spacer is on the outer wheel bearing side I believe.
Here is a great guide in case you need to refer to it. http://www.fordfestiva.com/forums/sh...hlight=bearing'90 LX
I have done everything that guide says but never seen a preload spacer. Now that I know thats what is missing, I must find one. Does 1-21 matter on the spacer?89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
Yes, needs to be the correct size to take up the slack, any less and you chewup bearings, any more and you likely will crush/overload the bearing on pressing them together.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Or find a suitable replacement in a yard. As has been stated above, without the spacer, 3 or 4 days is about all you get.Originally posted by wybnrml View PostYou'll need to get a spacer selection tool to determine what size spacer you will need.
1989 L - 247K miles Slick
easiest thing to do is get a good set from the yard like Batman has said or a set that needs bearings....and when you take them apart use the spacer that comes with them."FLTG4LIFE" @FINALLEVEL , "PBH"
I hope festyboy can hook me up. There isn't any aspires in any junk yard around here. I'll just replace the whole front end again. I'm not giving up!89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
Originally posted by EVOGUN View PostDo you have the old bearings spacer probably still attached to them.
Viola! I guess my brother read this thread and went out and looked at my OLD hubs, not the new ones, anyways sure enough my old hubs had the spacer which is a 11. I freakin love you guys, no homo BTW.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
Just the clarify, that spacer needs to be used with your old hubs.Originally posted by 91_festy_Gl View PostViola! I guess my brother read this thread and went out and looked at my OLD hubs, not the new ones, anyways sure enough my old hubs had the spacer which is a 11. I freakin love you guys, no homo BTW.
It is likely NOT the spacer needed by your new hubs.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Youll need the rotunda bearing preload tool to order the proper spacer - old hub with new bearings can mean a new spacer every once and a while you get lucky and its the same one - more likely you will be one or two spacers different - also spacers can differ from side to side as well
Borrow the tool - take em to a shop that has the tool or find one on eBay I see them all the time
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
So using the spacers that originally come with the knuckles wont work? My old hubs are shot because my brother used the tap in studs insted of the screw in studs for the conversion. The holes are bored out so there un-usuable. I guess this still means I need to replace the whole assymbly? This is getting rediculous. Atleast I have another BP swapped festy to drive. Im buying my brothers fester for 650. BP swapped with F-series hydro.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
^^ Using the old spacers on a different set of hubs will likely land you right back where you are now. Unless you are really lucky, and they happen to be the same for both sets.
