Crank dampener should be #1. Then wheeels and tire etc.....
best suspension
-Greg
Redneck Engineer
FOTY - '09
I like mine; does seem to give a little less body roll. Didn't feel like a giant change tho, I have to admit. Better low-pro tires would be the more important upgrade. But try the bar; they are cheap at the JY.Originally posted by sodikartracer View Posti dont see why anyone would put the aspire front swaybar on their car. Im pretty sure that would make it understeer worse... Sticky tires like Euro said and stiffen the rear of the chassis a lil should make a big difference. sounds like it shouldnt be half bad as it is.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
You got to decide what you want first... do you want something that is really really good for auto cross but pretty rough and bouncy on the street? or do you want something inbetween?
if you want something in between your setup right now sounds like the best for ride quality/autox performance
my current car has coilovers aspire sway bar and custom rear sway bar.. the rear swaybar helps ALOT
my spring rates are 375 250? i think?
oddly, and generaly, "more is better" with regards to the front sway bar..(IMHO)Originally posted by big_ty2003 View PostI totally agree with you, but some people have the attitude that "more is better"...
i have a hugeeeee 1 1/2 inch hollow sway bar on my miata road racer and a tiny one on the back.
also when i road raced the festiva i had an aspire front sway bar and it was mucchhhhh better around the corners and had half the body roll permitting me to keep my alignment right even through the corner and therefore was faster
i also ran one while i was ice racing .
