I just paid 225 for mine that was trailing arm and front spindles and front sway bar so you got a good deal.
Buying a aspire brake swap?
if it's a 5 speed, the trans will give you better acceleration and it's a bit stronger, the rear struts allow for more choice in tire/wheel fitment.
the aspire used a MAF system which aftermarket ECUs prefer to use...
and a few other things.Trees aren't kind to me...
Originally posted by FestYboy View Postif it's a 5 speed, the trans will give you better acceleration and it's a bit stronger, the rear struts allow for more choice in tire/wheel fitment.
Now the guy wont email me back...
88 Festy L (The White Thunder)
91 L came and gone, owned only 2 days
if it's auto, that means slightly larger brakes.
keep trying to get it, never loose hope! lolTrees aren't kind to me...
Here's the link to it, hope he emails me back, my buddy has some nice 14" rims that would look so good on my festy!
I've done the Aspire swap. Take the sway bar AND brackets, the knuckles, including hubs, the rear beam in it's entirety including the e-brake cable and make SURE you use the Aspire brake lines! Don't cut them, because it's necessary. The sway bar is 40% thicker. If you do install the sway bar, remember to drain the coolant system to pull the lower hose so you can trim it up a little so it doesn't rub or you will dump antifreeze on the highway. Oh and grab the spare if he has one!In love with a MadScientist!:thumbright:
Originally posted by DriverOne View PostI've done the Aspire swap. Take the sway bar AND brackets, the knuckles, including hubs, the rear beam in it's entirety including the e-brake cable and make SURE you use the Aspire brake lines! Don't cut them, because it's necessary. The sway bar is 40% thicker. If you do install the sway bar, remember to drain the coolant system to pull the lower hose so you can trim it up a little so it doesn't rub or you will dump antifreeze on the highway. Oh and grab the spare if he has one!
is it two door or four door?
two door stuff to get:
gas tank with filler neck, pump and sending unit (wiring is different...I need to do a search or figure a way to swap the connectors for the tank seal / pump mount)
complete exhaust
anything else I'm missing for 2 door?
non-two door specific:
brake booster adds a little braking power too but if your festy is a stick have fun getting it in. it's very doable but a huge PITB!
e-brake cable (excellent upgrade - also is insulated!)
front seats (have to swap the cushions over to the festiva rails but make good upgrades)
look for a hatch/gas door popper down by the floor/drivers seat (if it has that let us know)
are you getting the struts too along with the suspension, sway bar, etc?
if you can get the sway bar make sure you keep all the bushings and the two metal plates under the front of the car as they're bigger than the festiva's but bolt right up. I haven't done it yet but I looked it over when I carried my swap outta the PickNSave
make sure you also get the outer tie rod ends for an aspire swap (if in good shape)Last edited by walth; 03-04-2011, 11:05 PM.
If you get the Aspire Transmission, Make sure you get the front mount too. The Festiva one won't work. I tried the Festy one all kinds of ways, it'll never fit. The Aspire one will bolt to the trans with only two bolts, but works perfectly.Festiva: Because even my dog can build a Honda.
Devon, did you ever get these parts? The link is now gone.
Originally posted by Safety Guy View PostDevon, did you ever get these parts? The link is now gone.
Karl
Wow.
If you know where he is, go visit him with some money and your tools.
give him 50 bucks for the whole car and tow it home! there is a lot to gain from tearing apart a car you won't useand you get lots of parts to put on your own festiva or use as spares
Karl
Originally posted by walth View Postgive him 50 bucks for the whole car and tow it home! there is a lot to gain from tearing apart a car you won't useand you get lots of parts to put on your own festiva or use as spares
