Wheel stud kit
  • #31
    it shouldn't come out if it was installed properly. It NEEDS to be loctite-ed when installed to prevent back-out
    Jim DeAngelis
    kittens give Morbo gas!!
    • #32
      They are threaded from both ends. One end has about 1/2" of thread. Put locktite on this end and tighten it into the hub till the thread bottoms out. My haven't come off yet.
      matt
      • #33
        I take it you'd use the permanent Loctite? Or will the Loctite Blue do?
        • #34
          if you expect to get them out later, use the blue, but double-nut the stud and torque it down, about 25lb-ft. If you want them out later, but are willing to fight them, and really want/need them secure, use the red and torque them. If you never expect to have them out again, use the green!
          Jim DeAngelis
          • #35
            Thanks Jim. I want to convert Lux to wheel studs in the spring. I figure a true luxury Festiva should be easier to change a puncture.
            • #36
              will the 1.75 work i have the stock brakes no swap yet.
              • #37
                A little bit of thread ressurection, but I found a better source for studs. I went to Les Schwab and got some for $1 each, and acorn nuts also for $1 each. These studs are 1.78" long and have 1.3" of thread outside the hub.
                OX SMASH!!
                • #38
                  what is a les schwab?
                  must be a west coast thing...
                  ive been severely needing wheel studs to hold my 15" wheels on for a LONG time lol
                  its such a pita to put on wheels that arent hub centric onto a car with lug bolts! :evil:
                  • #39
                    Tire dealer, and I'm pretty sure they are west coast only.
                    After I got home and thought about it, I'm sure a screw or bolt dealer would be even cheaper. Something like Tacoma Screw. They do a lot of online stuff.
                    OX SMASH!!
