Originally posted by FestYboy
Installed Camber Plates!!!
Whats a Camber bolt?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
If you add caster,its going to make the steering feel sluggish in the tighter corners but better at high speed. So hopefully the Strut compression you are trying to overcome and the caster you are adding dont cancel each other out. Because if the strut aint compressed now you have more caster which you might not like. But its all good,I like people who arent afraid to try stuff. Good stuff Man-ThomasOriginally posted by floydiancomplex View PostThey both do lean slightly back towards the center of the car. This was done intentionally as to give addition caster which help a MacPherson Strut gain negative camber upon compression. I knew
I'd pretty much be running them maxed anyway so I set them up to give a bit more caster. Toe is
affected anytime an adjustment is made either way because you are moving the strut body in or
out. The strut is attached to the Hub which in turn is connected to the tie rod so any adjustment
Caster change aside will affect Toe.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
camber bolt: and offset eccentric bolt that replaces one of the standard bolts on a strut/knuckle connection. it allows for camber adjustment where there wouldn't normaly be any.Trees aren't kind to me...
Ahh Thanks for the clarification Festboy. I remember reading about it now,you have 2 options right? You can flip the bolt and gain an additional .5 or 1 deg. neg camber? But after re-reading your post. It sounds like simply using a standard bolt will give you even more?Originally posted by FestYboy View Postcamber bolt: and offset eccentric bolt that replaces one of the standard bolts on a strut/knuckle connection. it allows for camber adjustment where there wouldn't normaly be any.Last edited by nitrofarm; 03-29-2011, 06:47 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
potentially, yes, but that bolt had better be grade 8 or higher and have snug fitting washers.Trees aren't kind to me...
Sorry I was thinking of the upr strut mount plate that you can rotate 180. Yes I see now what you were telling me all along :banghead:Originally posted by FestYboy View Postpotentially, yes, but that bolt had better be grade 8 or higher and have snug fitting washers.
Are there any deg marks on the head of the camber bolt or do you just use a camber gauge to tell what your set at? Where did you pick yours up at? And @ how much deg variance did it give you Festboy?Thanks for the help-Some people like to read fiction,I prefer to read repair manuals. Weird I know-
use a camber gauge. didn't need any yet but can easily find them on the 'bay. remember that Scrappy is already at -2.4* per side. that's pleanty for the street. lolTrees aren't kind to me...
CoolBeanzand thanks for the good info my man.Thomas-Originally posted by FestYboy View Postuse a camber gauge. didn't need any yet but can easily find them on the 'bay. remember that Scrappy is already at -2.4* per side. that's pleanty for the street. lolSome people like to read fiction,I prefer to read repair manuals. Weird I know-
