^yes sir i think i will and see what happens the police officers that i talked to said it wouldnt fall under that because its not electric they said it shouldnt be any different that a vehicle wrap or putting reflective vinyl on a car.
well its taking alot longer than i thought (but what else is new) because i ordered only two cans of paint but i have one whole wheel done so i thought is show some pics
heres the original wheel before prep and prime
heres the white prime base coat
me and my wife just havign a fun photo shoot
and finally here is the finished product!!!!! i couldnt get a good glow pic but ill try again i forgot to put the camera on the rite light setting
i masked off one spoke and put funbox on it because thats what everybody calls the festiva. so anyway theres the update. the other cans are on the way i bought 8 this time so there will be 0% failure!!!
got some pics of my car in the daylight with the wheels on finally! ill take some night pics tonight with the wheels glowing hopefully. talk about a tight fit i had to beat and roll multiple times to get them under there i dont know the offset but im sure its rwd. i still have rubbing issues especially in the rear and especially when i have more than myself in the car! i will still need to beat and roll some more i already tore into one of my rear tires because of it then beat the fender alittle more but without further wait here is the funbox with new shooze car is alittle dirty and i havnt cleaned up the adhesive that held on the molding that i decided to take off so forgive me
^Love! Just went through the entire thread real quick. How does the glow paint work? How much did you spend on paint to do them? Clearcoat them? This inspired me to get a little wild with my wheels
heres the link to the site where i bought from they have a plethera of colors and color options white that glows green, red, purple... white that glows green, red, blue... blue on blue green on green... $9 dollars per 4oz can. alittle expensive but worth it about 2 cans per wheel i got 2 left over for touch up or other stuff they sent me 1 free for ordering so many. simply let it get some light preferably sun for at least 15 min and they charge and glow. i didnt use clear because there is uv blocker in clear coat if you do use clear they recomend the cheapest possible clear because cheap stuff usually has less uv blocker.
165 60 from onlinetire.com but like i said my offset is rediculous take the rear off and beat the lip on the fender in that should do it but makesure you go all the way around the fender not just most i found out the hard way that i should of
yeah, i rolled the fenders with a fender rolling tool. and even cut the inside lip of the bumper back and hammered the body seam up, but it still rubs, doesn't help I'm on 2.5 inch cut springs.
