this is my 2nd one in 2 years. i can take the boot loose and grab the inner tie rod end joint and wiggle the inner rack itself up and down quite a bit... am i the only one?
is any one else breaking/wearing out steering racks?
The right side of the rack in the aspire has been doing that for about 4 years. Thought it was the inner so I bought a new one and I took me a few months to decide to install it when I found out it was the gear bushing. What makes me mad about it is it was a brand new, not reman Ford rack and pinion I bought new in 01 from work. Was around 320 dollars cost/ list was over 500! Rack only has about 30k normal miles on it. I've been looking for one to swap in while I take it apart to see if I can fab a new bushing.Tim
'97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
'03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
'95 SVT Aspire B3T, Green Mica, 75k miles - DD
'01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
'89 Suzuki FA50 Bright Red - Lake Transportation
Cardomain.com/id/aspiresvt
Previous Vehicles
'92 Festiva L "Sport" Green Mica
'92 Festiva GL Blue Pearl
'92 Capri XR2 Performance Red
Mine rattles over bumps like a bad inner tie rod but the inner is fine and it doesn't seem to move forward or backwards from what I remember just up and downLast edited by Aspire SVT; 12-04-2011, 11:48 PM.Tim
Previous Vehicles
Does it make any noise while drivingTim
Previous Vehicles
both of mine are "loose" feeling, but nothing in there seems broken.
are you talking about the rack itself? cause i know there's a pin on
either side that's supposed to hold it in place up right. the only
movement you should have in the rack itself is left to right on the teeth.Fesdiva is it's new name since she's acting crazy- 92 L
I HAD that problem. After replacing it once (PITA) I decided to make a fix.
I made a delrin tube that fit around it.
Then i cut it in half and slid it in as halves. Then i drilled and used roll pins to hold it in place.
I think all the high hp cars will suffer from this.-Greg
Redneck Engineer
FOTY - '09
Hmm i wonder if this is the clunking sound i've been hearing in my festiva, i have not been able to find the noise at all, so i'll have a look on mine to see
Originally posted by eurotiva View PostI HAD that problem. After replacing it once (PITA) I decided to make a fix.
I think all the high hp cars will suffer from this.1988 Chevy Sprint Turbo 997cc
my red stocker with 280k mi on it is doing this... annoyed the crap out of me for a while. Apparently you can still get the factory bushings, Jay has done it for a few people.
I'm interested in finding a better fix though. Greg you got any pix of what you did?~Nate
Current cars:
FOTY 2008 winner!
Originally posted by skeeters_keeper View PostGreg you got any pix of what you did?
Any upgrades that can be done with a welder and scrap metal are ones I'm interested in! :lol:1990 White L-Plus 5-speed rust-machine
Scrapped
1991 Blue L 5-speed
daily driver, intermittent project
1993 rustless wonder
A shell, awaiting suspension, brakes, and B6T
