Originally posted by zoom zoom
Axle cheat sheet
Thanks for the props Zoom,make sure you stand the axle on its end (Input) and compress.Then while you have your tape measure on the table next to the shaft measure all the way up to the flat that would butt up against the race. I know "Personally" that the Festy/Aspire measurements are dead nuts on. And if you dont need the abs ring you can just knock it off with a punch.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
It depends what trans you use.Originally posted by bobbyspider View Posthate to bring up old stuff but just saw this and was wondering if any of these axles would 100% eliminate the need for an xr2 axle on an aspire bp swap. thanksSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Rio Axle's are plug and play for the G seriesOriginally posted by bobbyspider View Postoops, yea i guess that would help out. sorry it is a cable g seriesSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Know one has stepped forward to give me the exact length of the XR2 intermediate shaft. So I cant tell you the exact combined length yet. All I know is that member Shadetree says they fit fine. And I trust him that the Rio axles end up being correct. It makes sense considering that the Rio is loosely based off the Aspire platform. And the Rio uses a G series case with what appears to be a F series diff.Originally posted by bobbyspider View Postand are the same length as the xr2 side with the intermediate shaft correct? i know this will have more torque steer but im cool with that ill figure somthing out when it comes boost timeSome people like to read fiction,I prefer to read repair manuals. Weird I know-
nice organized info ! appreciate the work.93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
Oh I should add that ZOOM ZOOM graciously measured the overall length of the XR2 vs Rio setup.His results are posted above ^^^^Thanks Zoom!Some people like to read fiction,I prefer to read repair manuals. Weird I know-
the image has dissapeared.Originally posted by nitrofarm View PostI have a hard time processing info,spread sheets help me.So I made this,hope maybe it can help someone else. I made a couple observations:
Using a 02 Rio knuckle on a Festy,appears to require lengthening the Tie Rod @ 1" total.Using a Rio knuckle on a Aspire is almost identical as far as width goes.
Rio's track width compared to Aspire's are 1/16" wider.But use axles that are 1/8" shorter.So are they changing track width via rim backspace? How is track width measured? From outside edge of rim,or center line of rim?
F series tranny in Aspire, you can use na Capri axles with only 1/16" difference in axle overall axle width.
Anyone know the track width for the na Capri?Ford Festiva 1991 WA Model (5 Door)
Nicknamed the car 'The Chiva' (Chilli Festiva)
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
Why didnt he go with the XR2?Originally posted by bobbyspider View Post^ yes. he has the rio one installed but hasnt drivin it yet but from hes tests he said it doesnt bind under turning or suspension flexSome people like to read fiction,I prefer to read repair manuals. Weird I know-
I haven't been able to do the machine work to the xr2 axel yet. A hole needs drilled 3/4" from the current hole since the BP is longer. The Rio axels are in this transmission and in the hubs right now..like I said I removed the springs and turned the axel and it didn't bind but I haven't driven the car yet, so its still a 'do it at your own risk' thing like everything else. After seeing what happens when the wrong length axel is used firsthand I don't want to be responsible for someone wrecking their car.
I can also tell you that a Festiva auto, aspire auto, and aspire manual axel is the same length from the outside hub end to the tripot bearing. The inner CV cup is almost an inch longer for festivas, and the spline counts are different mtx/atx.Last edited by zoom zoom; 01-22-2013, 02:12 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
