Axle cheat sheet
  • #46
    Just thought I'd share this axle pic.(the axle in the rear)Its a LH Aspire from NAPA pn 95-7194. The thing that caught my eye is that it measures 24".It measures right in between the Aspire & Festy axles specs. Basically its just an 1/8" longer than a Festy and 1/8" shorter than an Aspire. But the really nice part is the inner joint,it gives you @ 3/4" inch MORE movemant. So if you arent running a butt load of neg camber,this axle should work pretty good in a Festy. I have a Festy axle below it so you can see the comparo of the two.
    Also the axle shaft is beefier in the center portion(but this doesn't affect the spline fitment) If you have lifted Festy this axle would be a very good choice-:thumbs_up:
    • #47
      sub'd
      • #48
        Ok heres what I have found-the Napa piece is exactly the same length as a Festy from Advance ! So you get a much better axle with more plunge.(its hard to snap pics and push and hold the camera at a good angle,so have faith they are the same) Here are the pics to show how I measure to determine this fact. Installed the axle nut on backwards and spin it on till its flush with end of axle. Steel ruler on bench up against concrete wall.Lay axle on table parallel with ruler and nut up against wall.Push HUB end IN as hard as you can till axle bottoms out. Check your dimension (this will be the factory spec). On a side note if you get a measurement that's off by @ 1/16-1/8" It may because you have a used axle and the end is "Mushroomed" from someone beating on the hub end. Also I included some brackets I made to "Center" my tranny. I'm running a poly mount in the front now.
        First two pics are the Aspire
        NEXT the FESTY
        Here is An Aspire RH on top of the NAPA & Advance axle's. Note how the NAPA RH doesnt have the same engineering as its LH brother !
        NEXT my "Adjustable" mount bracket
        • #49
          The lower axle is an aspire axle, middle one is a festy axle. The fact that fully compressed they measure the same proves what I've been saying for awhile, the axle shafts are the same length. Only difference is the inner CV. I'm NOt trying to act like a know it all or anything like that but I'll bet you dollars to donuts you can go buy 10 Festiva axles and 10 aspire axles and they will all be mixed and matched. Aspires have a wider track width.
          Also it was just a typo in my last post in this thread, you obviously know what I meant now..
          2008 Kia Rio- new beater
          1993 Festiva- Fiona, DD
          1997 Aspire- Babyspire, DD
          1994 Aspire - Project Kiazord
          1994 Aspire- Crustyspire, RIP
          • #50
            Hey Matt you are very helpful when it comes too info,never thought of you as a "Know it All". Anyway you are correct about the mix and match. Thats how I stumbled onto the NAPA unit. A true Aspire axle is 1/8 longer when fullycompressed. But the beauty about the NAPA piece is its sa short as the Festy but has @ 1.5" more travel. I've only seen this axle available from Napa btw
            • #51
              Do you still need measurement of XR2 midshaft? I have a set in the garage. I can get midshaft length and total length if needed. just lmk
              -Bryant
              • #52
                Thanks Gomez, Matt hooked me up with a set. I will get off my Butt and measure it
                • #53
                  Well I finally did i,t after two years of driving an Aspire with a Festy gear box.I installed an Aspire gear box in my Aspire. Weird I know but MPG was the ultimate goal.Here is the mount I made up...Because of the smaller dia of the Polyurethane I'm able to mount right on top of the cross member.The 4 hole is the Aspire in case your not familiar with them. Next up is the Rio gear box. Couldnt resist posting a pic of my car when its clean (or cleaner than the normal dirty)
                  • #54
                    This is a great thread and I don't want to start any more confusion then what's already out there .
                    Does anyone know if the Capri xr2 jack shaft will connect to a escort gt axle . As the same combination would be the escort gt jack shaft connect to a Capri xr2 axle ?
                    Im looking for an axle combination for a high and wide festiva . Thanks
                    New build on the way .
                    • #55
                      AFAIK they are the same. Only difference that I've seen in photos (I have xr2 one) is the mounting hole positions where it bolts to the motor.
                      1988 MAZDA 121- B6T + G5MR SWAP IN PROGRESS.
                      • #56
                        That's what I'm thinking but just wanted a positive, before I go buy one .
                        • #57
                          thanks shade
                          -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
                          -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
                          • #58
                            I believe the escort Int shaft is actually an inch longer then the XR2 shaft... Hence why the mounting holes are an inch different with a BP/XR2 shaft
                            • #59
                              Omg that would be perfect
                              • #60
                                Yes they are the same, but the egt is longer
                                -Greg
                                Redneck Engineer
                                FOTY - '09
