Originally posted by FestYboy
rim size question
look into factory 98-02 honda accord 16" rims with 195/40/16 tires. you'll likely need spacers for the rear to clear the strut.Originally posted by Tiaan View PostHi guys. i'm wanting to get some wheels for my 1989 festiva/ mazda 121 and was wondering the biggest size rim possible without rubbing. THANKS <3Trees aren't kind to me...
^ no, it's not safe, but people do it anyway due to ignorance. really, any spacer should be bolted to the hub and have provisions to support the center hole of the rim built into it. also, any spacer should be used with longer lugs, or studs to make up for the new position (again, people ignore this part as well and it often ends badly for them).
the issue with running big rubber is the rear strut location. it doesn't allow for much above a 175 without having to massage the fender. really, a 6" wide rim is about the limit without moding the car in some way (hence the suggestion of the Accord rims, they're 6" wide)Trees aren't kind to me...
