I get my springs through www.southwestspeed.com
You'll also need kia Rio (2001) strut bearings.
Also, I suggest a stiffer spring in the front, like atleast 180lb. With the b6t and g series your putting a lot more weight on the front wheels because the engine needs to be moved forward about an inch from the stock location. This added inch with the added weight of the heavier drive train relates to a lot more pressure on the front suspension. The 200lb springs on my car are very comfortable and perform well. The car rides smoother over bumps than stock
