Custom strut bar mounts
  • Custom strut bar mounts
    I've wanted to do these for a really long time now, but they've proven a challenge. Very hard to cast to net shape, so I really didn't bother. Now that I've got the mill I can use it to my advantage :evil:
    I had one of these strut bars back in the day. Total crap:
    I purchased one of Corksport's last strut bars for the 323 GTX when they discontinued their BF chassis stuff. Super stiff bar, with really rigid and well designed mounts. Visible in this pic:
    However even this was not perfect... the GTX does not use a 4-bolt strut mount, so I had to drill it out to use it on the Capri. No room for the nut on the stud there. Plus, I wanted some of my own design!
    So I made this pattern this morning, based off the CS style mounts, with some of my own twist in the design. Pattern is made from MDF, pine & bondo lol
    Which I cast two of this evening. No casting pics as I was busy molding
    Corksport vs. casting. Casting is solid
    Machining the slot:
    Skip a couple steps, sprinkle of magic, and tada - new strut bar mounts. Added bonus, I open my hood and there's some of my work right there in your face Excuse the filthy engine bay, I have not brought the GTXR2 out since winter, she needs a good cleaning. Ill try to get better pics tomorrow
    So now I've got a super extra tough strut bar. I might machine another set of castings to use a single heim joint at the top to make things a bit easier
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
    You've got skills man!!
    60% of the time it works, every time!
      Festys only have a 2 bolt top mount, those look awesome, but would it work on a Festy/aspire if you closed the circle on the backside?
      2008 Kia Rio- new beater
      1993 Festiva- Fiona, DD
      1997 Aspire- Babyspire, DD
      1994 Aspire - Project Kiazord
      1994 Aspire- Crustyspire, RIP
        That....is....awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
        Tyler
        91 Festiva, 5spd, B8 swapped, now for paint and suspension
          Can you make us some for the Festivas? Great work!
          Semper Fi til I die!
          1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
            Looks nice and sturdy Rocket!
              If someone local to me wants to come spend an afternoon at my place so I can build up a pattern, I certainly can!
              Rocketchips!
                oh OHHH that's ME, I wanna do it!!!
                  :cheers:Nice job Rocketman!
                  All the many braces I've seen are too flimsy to work, at all.
                  You have crafted an excellent system:cheers:
                  No car too fast !
                    Interesting... I was actually thinking of making some strut bar ends with additional bracketing to allow me to run tie bars to the front unibody and one to bolt to a plate on the firewall... Really stiffen the front end up. I'm sure we have all seen the dyno video of the 300+ whp festiva where the front end flexes more than Arnold back in his hay day.
                    Facebook Me!
                      Just let me know your availability, PM me for my number and we'll work things out. I need a good solid afternoon figure 4-6 hours
                      Thanks! I wanted one that would actually WORK. I think these will do it
                      Yeah I remember that video...ridiculous amount of flex. I could easily make a firewall plate for mine...stop givin me ideas! I just finished this lol
                      Rocketchips!
                        Couple more pics now with daylight
                        Rocketchips!
                          DO IT!
                          Facebook Me!
                            Rocketman, what would we do for the middle bar portion of the strut tower brace? Would you make those pieces too?
                              Damn, I am one day late with my festiva strut bar!
                              Anyway, it looks like on festiva strut towers are maybe 3 inches under the hood, so with festiva you need a mount to be much higher in order to clear the intake manifold
                              better pics coming later, but even on this one you can see the angle bracket going up:
                              rusEfi - DIY ECU
                              93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
