so im wondering if I found a shock that had same extended height as the rear strut and same compressed.then what would be the issue with just removing the rear strut assembly and just running these shocks.they say you can run up to 150psi or as low as 20. I was hunting through pick pull today and saw a Cadillac Fleetwood with rear air shocks had a nice little compressor run off 12v. if you get where im going this seems like would be easy and work good.but only if you could run with no spring? and mainly back to the supporting a load is the only reason and its cheap. heres a link to get an idea of what im talking about.
let me know what you think
also check out video but I just want rears
