Bought a 91 Festiva L. Scary Sloppy Suspension.
    On the L series, at least in 1990 when I bought mine, the passenger mirror was an option. Of course, so was the radio and antenna. The antenna was a 43.00 option at the time. ( mine had no radio either).
    Oh and Welcome to the site. I hope you can make it to Madness on Oct 5.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      The above link parts should work fine but I would check with rockauto.com before I bought them. At rockauto, you can get Moog parts which cost a little more but are better parts.
      Jerry
      Team Lightning
      93 L Lightning. BP
        That is so incredibly bizarre to me that a side view mirror was an option lol. Aren't you just as likely to switch lanes to the right? The guy told me that it didn't have radio or ac but it does have the antenna a radio and speakers none of which currently work but makes my life easier when adding the stuff in. I just bought a 25 dollar Media Center AM/FM Radio from Walmart.com and the wiring harness hoping that it is a simple fix. Although there isn't a listed radio fuse on the panel.
        My Festiva Youtube Channel.
        Skittle and Pesty.
        Skittle: 91 Festiva L (143K)
        5 Speed. Aspire Swap. Aspire Booster/EGT Master Cylinder. B6-ME. MSD Streetfire. Miata Seats. Daisy Rims.
        Pesty 88 Fextiva LX
        Aspire B3. 5 Speed. Aspire Swap. Miata Booster/Master Cylinder. Microsquirt. Volvo Turbo. Innovate Wideband O2 sensor. Protege Seats.
        Rativa: 89 Festiva LX (Carby) (223K)
        Donor of Life.
        Whitestiva: 91 Festiva GL (236K)
        Auto. Donor of Life.
          Radio, AC passenger side mirror, radio antenna (if you didn't get the radio) all were options. Speaker wise, you can put 4" in the dash and rear panels or 6.5" in the doors.
          Jerry
          Team Lightning
          93 L Lightning. BP
            Do these cars do alright on the interstate? I do alot of interstate driving as an actor and hoping to be able get some solid interstate miles out of this thing before its all said and done.
            Skittle and Pesty.
            Pesty 88 Fextiva LX
            Donor of Life.
              Mine will cruise at 70-75 all day without any issues. (it has 332K+ miles on it). At those speeds I get about 35 mpg +-3mpg. And that's uncorrected as I"m running 14" wheels with 185-60 tires. And they are a blast in the mountains!!
              Jerry
              Team Lightning
              93 L Lightning. BP
                Originally posted by nc_festiva View Post
                So I just bought my first festiva for 960 this morning.
                Judging by how well the car was maintained originally I do think it is premature to say 'the stock festy brakes don't have enough stopping power'. Likely as not they're similarly useful as is the suspension at present. Learn how to service what you've got before you get all wound up attempting to tackle with swaps! There are lots of hang-ups, learning curves and improvising involved once you leave "the beaten track" of simply trying to keep a car serviced and going.
                Steel Metro/Swift/Geo rims from the 90s are direct fit 13s by the way, until such time that you gather up the finances, parts, experience and courage to take on the Rio/Aspire leap over to 4 X 100 bolt and a whole new Festy world.
                  idk about this.my first add on was aspire suspension within a wwek of owning it.my seond car was 2 days of owning it.
                  • #24
                    It will after you get the suspension stuff all sorted out.
                    That was taken while driving my car on the interstate with the stock 197K B3 and a burnt exhaust valve on #3 cylinder :mrgreen:
                    WWZD
                    Zulu Ministries
                    • #25
                      I had two b3s burn #3 too....
                      First was stock 280k, burned.
                      Replaced valve 80k later burned again.
                      So did a complete master bore and build, cut seats 45* and 44* on faces, per dad's old 70s Chilton that recommends that cut on engines notorious for burning valves....
                      And these small valves do so.
                      I'll keep posted if I smoke another exhaust valve...
                      • #26
                        ^^ It's a common problem with the B3's tiny exhaust valves. They're too small to dissipate heat effectively so they just cook and then burn. Removing the shelf on the short turn side in the exhaust runner seems to help.
                        WWZD
                        Zulu Ministries
                        • #27
                          Only way to beat that game is sodium filled stems... Our 332hd to this day still glows the manifolds cherry red, after a hard 80,000# pull, night time, 1am, jump out, red hue under the truck......
                          I've watched the oil pressure climb in synch as the temp drops just idling.
                          • #28
                            This isn't my first car, just my first festiva. I've done multiple suspension jobs on my truck. Although I have 80 percent decided to just replace the worn suspension with new parts and get an alignment and see where that gets me.
                            Also as far as wheels it was a wash at the pullapart. Checked all the suggested vehicles and notta. Also checked most of the vehicles on this list that my buddy sent me.
                            These are some wheels that will fit the Festiva
                            4.5 inch
                            1997 Acura- CL 16 x 6 (5 straight spokes)
                            1998 Acura- CL 16 x 6 (5 dual straight spokes)
                            1998 Acura- CL 16 x 6 (7 straight spokes)
                            1990-89 Acura- Legend 15 x 5.5
                            1996-95 Acura- TL 15 x 6 (5 straight spokes with groove)
                            1997-98 Acura- TL 15 x 6 (11 straight spokes)
                            1994-92 Acura- Vigor 15 x 6 (11 triangular slots)
                            1999-98 Chevrolet- Metro
                            1989-85 Chevrolet- Sprint
                            1991 Dodge- Colt Vista 13 x 5 (15 slots)
                            1993-92 Dodge- Colt Vista 14 x 5.5 (5 straight spokes)
                            1992-84 Eagle- Summit/Summit Wagon
                            1992-91 Eagle- Summit 13 x 5 (15 slots)
                            1993-88 Ford- Festiva 12 x 4 40mm offset
                            1993-91 Ford- Festiva 12 x 4.5 40mm offset (8 elongated triangle slots) 1997-89 Geo- Metro
                            1999-92 Honda- Prelude
                            1999-90 Honda- Accord
                            1999-91 Hyundai- Elantra
                            1995-92 Hyundai- Elantra 14 x 6 (16 slots)
                            1995-92 Hyundai- Elantra 14 x 5.5 (7 curved spokes)
                            1998-96 Hyundai- Elantra 14 x 5.5 (5 straight spokes)
                            1999-90 Hyundai- Accent/Excel/Pony
                            1994-92 Hyundai- Excel 13 x 5
                            1991 Hyundai- Sonata 15 x 6 (18 rectangular slots)
                            1994-92 Hyundai- Sonata 15 x 6 (9 triangular slots)
                            1996-95 Hyundai- Sonata 15 x 6 (9 straight spokes)
                            1997-95 Hyundai- Sonata 15 x 6 (5 twisted spokes)
                            1998-97 Hyundai- Sonata 15 x 6 (5 straight single groove spokes)
                            1995-90 Hyundai- Scoupe
                            1992-91 Hyundai- Scoupe 14 x 5 (6 curved spokes)
                            1995-93 Hyundai- Scoupe 14 x 5 (5 curved spokes)
                            1998-97 Hyundai- Tiburon 15 x 6 (5 twisted spokes)
                            1998-97 Hyundai- Tiburon 15 x 6 (5 raised straight spokes)
                            1989-81 Mazda- 323/GLC
                            1985-84 Mazda- RX7 GSL-SE 14 x 5.5 40mm offset
                            1991-86 Mazda- RX7 14 x 5.5 40mm offset
                            1987-85 Mazda- 626/MX-6
                            1994-91 Mercury- Capri 14 x 5.5 45mm offset (16 holes)
                            1994-91 Mercury- Capri 15 x 6 45mm offset (3 curved spokes)
                            1994-91 Mercury- Topaz 14 x 5.5 (16 holes)
                            1998-92 Mitsubishi- Expo/Expo LRV/Vista Wagon
                            1994-92 Mitsubishi- Expo 14 x 5.5 (5 straight spokes)
                            1999-84 Mitsubishi- Galant
                            1991 Mitsubishi- Galant 14 x 5.5 (18 slots)
                            1991 Mitsubishi- Galant 15 x 6 (8 straight spokes)
                            1991 Mitsubishi- Galant 15 x 6 (5 straight spokes)
                            1993-91 Mitsubishi- Galant 14 x 5.5 (15 slanted spokes)
                            1992 Mitsubishi- Galant 15 x 6 (5 straight spokes)
                            1993 Mitsubishi- Galant 15 x 6 (8 triangular and 8 rectangular slots)
                            1993-84 Mitsubishi- Mirage
                            1993-91 Mitsubishi- 2000GTX 14 x 5.5 (18 slots)
                            1991-80 Mitsubishi- Tredia
                            1999-93 Nissan- Altima
                            1995-82 Nissan- Stanza
                            1991-84 Nissan- Maxima
                            1990-78 Nissan- B310/Pulsar
                            1986-82 Nissan- Sentra
                            1993-84 Plymouth- Colt
                            1985-79 Plymouth- Arrow/Champ
                            1999-89 Suzuki- Swift
                            1991-80 Toyota- Cressida
                            1985-80 Toyota- Celica
                            Any thoughts as to the accuracy of this list? Also if I was to go to a 14" inch rim are there any major downsides? Such as significant loss of mpg or acceleration or extra strain on the brakes?
                            I was able to get the side trim that i was missing on one side of my festiva. Also got the strut for the rear hatch but that was about it most of both the festivas were stripped.
                            Also got an excellent pair of escort seats that still had very firm fitting foam. Also pulled the cubby as it had a built in shelf that mine didn't.
                            Skittle and Pesty.
                            Pesty 88 Fextiva LX
                            Donor of Life.
                            • #29
                              Also interestingly enough Ford has to different color teals. Mine is more bluish aqua than the one at the yard today. And unfortunately the driver fender was beat up worse than mine.
                              Skittle and Pesty.
                              Pesty 88 Fextiva LX
                              Donor of Life.
                              • #30
                                Hey guys is this the miata cylinder/booster I need? If it is I will go ahead and get it since it has free shipping and its only 49.99. Let me know.
                                Thanks
                                Skittle and Pesty.
                                Pesty 88 Fextiva LX
                                Donor of Life.
