Looks good. I thought about the taurus studs for the one flat side.
4x100 Redrill Template
Yeah, the flat side helps because you are getting really close to the transition from flat to vertical on the bearing part.Any difference that makes no difference is no difference.
I CNC routed a drilling template and turned a drill guide on the lathe. Should get the same results
I did these for Gomez (i think?), no word on performance yet AFAIK1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
^ That's awesome!
Think he sold them. I know they were up FS a while ago.
Looks like you also spotfaced the backside of the holes. Nice touch.
EDIT: Yeah, he sold them. http://www.fordfestiva.com/forums/showthread.php?55528-New-Festiva-drums-drilled-for-4x100-and-w-studsLast edited by sketchman; 12-12-2015, 03:23 PM.Any difference that makes no difference is no difference.
Ah okay. Yes I milled the back side to remove the rough cast surface, just enough so the stud heads would sit perfectly flat.
I still have the template somewhere.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
They are working fine.
So it will work.Any difference that makes no difference is no difference.
Got to put some speed on them. They are fine up to and beyond the 85mph reading the stock cluster can do.
So I'm saying if you have the mental and handiness ability this is totally a safe way to do it.Any difference that makes no difference is no difference.
Where can I get the rear drums to drill new holes in?1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
What size do i drill to for Dorman part # 610365!1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
If i drill to a ø.500 do i need to press the studs in or can i use a nut to pull them in? I have a press at work but would rather only ask them to drill it for me.
I could use a brass washer under a nut to help.
Or i could just come in on a saturday and have all the time i need to use the press.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Yeah, 1/2" is a good tight fit. I didn't think about the nut thing. I had a press handy, so it never occurred to me. Nice tip.Any difference that makes no difference is no difference.
