Well my aspire swap is finally all on... took long enough for me to finish it, and had a few issues along the way. now i'm having more..
i put the rear on first, and drove it for like 2 days like that. Rattled a little, fixed that. Seemed to handle much better on corners so i was happy. ebrake even works now! the brake seemed a bit squishier though.. i figured i'd blead the lines a but more later.
then 2 days later i did the fronts. bent my stinkin tierod end, replace the whole steering rack with one from carbonVmax. taht was a pain too, but i got it done. new tierod ends, lubed the balljoints, new calipers, etc. everything goes on easily, drive it a bit. verrry squishy brakes. blead more and more. and more. still seem squishy. any ideas on that one? just keep bleading?
after i had just finished the swap i drove it some, and it pulled right and vibrated some at higher speeds. had an alignment done and it doesn't pull right any more, but i ahve the 60-70mph shakes! i never really had them before. what oculd be causing this? i'm going to try swapping the tiers from the front to the back, to see if the steering wheal still vibrates. if it doesn't that i'll have those two balenced. if it does i'm not sure whats up.
also, i don't seem to have much traction... with 175/70R13s up front on aspire steelies. i expected to not be able to spin the tires very easily. seems just as easy/easier to spint them now and i seem to brake loose on hard corners a lot too..
well, if i can get my brakes working right and the vibrations gone it will be a nice swap
