Are they're any options to quicken the steering on a festiva? I see quaife sells gear kits, but obviously nothing made for our cars, maybe something could be adapted. also found this rack made for a Yugo, 2.4 turns lock to lock. Yugo's have the same front track width as a festiva (55.1 inches if I remember correctly). Wonder if it could be adapted, mounting may be a challenge
quick ratio steering rack
My 90 has an Aspire manual rack under it with the Rio struts on front. It turns quicker and tighter than my 92 BP car with stock struts. I'm sure someone will say that the Aspire manual rack won't make that difference, but it does.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Our fix is the power rack from an '02-'05 Kia Rio, un-powered or powered.
Almost a direct fit, just add Festiva side rods, and one bracket needs the mount holes elongated a little, the other is replaced by the Festiva one.
A little heavy in the parking lot (un-powered), but great on the road!Last edited by Advancedynamix; 01-13-2016, 02:00 PM.No car too fast !
I would like to upgrade my rack as well. I need to upgrade or rebuild. I hate just rebuilding.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
I would think a simple cap. I might give a power unit a try in a non power setup.
But what would lock to lock be on the powered unit in a non powered setup?1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
On the power racks I've run before without power, I took all the fittings off and just left the holes. You may want to glue some foam in them or something to keep critters and junk out. If you cap them then pressure will build up in the rack and make it harder to steer. The power steering fluid doesn't lubricate the rack or anything like that. You'll want all the fluid out of the rack or it'll squirt all over when you turn.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I did a couple of pipe nipples with a U hose on the fluid inlet/outlet as we plan to fit a power system, work in progress complicated by the need for a V belt pump so I don't have to pull down the Dealer installed ACOriginally posted by bhazard View PostWhen you run a power rack unpowered, what do you do with the fittings?No car too fast !
Lock to lock is unaffected, the manual rack will have a different ratioOriginally posted by mikemounlio View PostI would think a simple cap. I might give a power unit a try in a non power setup.
But what would lock to lock be on the powered unit in a non powered setup?No car too fast !
This will increase steering effort if there is fluid in the rack. Hydraulic pressure builds in the rack because of the flow restriction of the nipples and hose. If the rack has no fluid then it shouldn't be noticeable and this is a great way to keep critters and junk out. You don't want critters messing with the nipples on your rack.Originally posted by Dragonhealer View PostI did a couple of pipe nipples with a U hose on the fluid inlet/outlet as we plan to fit a power system, work in progress complicated by the need for a V belt pump so I don't have to pull down the Dealer installed ACDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
