Ultimate street suspension alignment
  • Ultimate street suspension alignment
    Hi, im in the process of ordering all the stuff i need for the ultimate street suspension, and was wondering that the best alignment set up is for it. I have 14 inch rims with 165/55 atr-k's (if that matters). Thanks!
    I run -3 camber up front -1.5 (factory aspire camber)in the rear. 0 to 1/16th tow in up front and whatever the factory rear aspire is.
    It drives really nice and stable on the street and is good on the autox corse.
      What I've been running.
      Sent from my SCH-I545 using Tapatalk
      Better Than Nothing Racing
      Way too many cars
      :woc:
        Thrust angle for road crown?
        A mechanic knows how; A technician knows why.
        Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
        Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
        Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
        FB Festiva page: Jared Bennett
        Instagram: jaredbear82
          Too lazy to try to fix it lol. Those shims are a pita to adjust. As long as it's close to 0 and your toe is 0 it doesn't really matter.
          Way too many cars
          :woc:
            Hows tire wear with that much camber
            CURRENT. Past
            88 festiva L. 89 xr4ti
            14 foST. 89 xr4ti
            82 F100. 97 silverado
            82 GS1000. 06 h3
            82 GS750. 79 ta 6.6
            74 TC185. 89 turbo katana 600
            69 T500. 80 gs1000
            15 sonic 82 cr480r
              If you set toe to zero so they're not scrubbing then it's not bad. I had Achilles on my red car for around 20K miles with no major camber wear on the rear at -3.5ish, even with a few autocrosses. The front tires didn't last long since I drive it hard on the street and autocross it, but that's not from camber. I did get around 6K miles out of a pair of soft compound Nankang NS2R's on the front, and that was with a couple autocrosses. I thought that was pretty decent for not rotating them.
              This is a Federal I had on my white car, -3.5ish and zero toe all around. Has around 3-4k miles when I took that pic and there's no noticeable wear from camber.
              '88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
                I've had similar results with my car at -2.5° to -3° degrees of camber all around. Street tires have no odd or unusual wear with 5K and auto-crossing. Toe will eat tires much fast than camber since it produces a grinding like effect on the edges.
