Hi, im in the process of ordering all the stuff i need for the ultimate street suspension, and was wondering that the best alignment set up is for it. I have 14 inch rims with 165/55 atr-k's (if that matters). Thanks!
Ultimate street suspension alignment
Thrust angle for road crown?Originally posted by shorestiva View PostWhat I've been running.
Sent from my SCH-I545 using TapatalkA mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82
If you set toe to zero so they're not scrubbing then it's not bad. I had Achilles on my red car for around 20K miles with no major camber wear on the rear at -3.5ish, even with a few autocrosses. The front tires didn't last long since I drive it hard on the street and autocross it, but that's not from camber. I did get around 6K miles out of a pair of soft compound Nankang NS2R's on the front, and that was with a couple autocrosses. I thought that was pretty decent for not rotating them.Originally posted by Thebrandonbeezy View PostHows tire wear with that much camber
This is a Federal I had on my white car, -3.5ish and zero toe all around. Has around 3-4k miles when I took that pic and there's no noticeable wear from camber.
Last edited by theastronaut; 07-14-2018, 10:24 AM.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
'89 L B3-5 speed-A/C-Advanced Suspension
Project Goldilocks '66 C10 Short Fleet BBW Build
'65 C10 Highly Detailed Stock Restoration Thread
'55 International Metal/Body/Paint Work
'66 F100 Full Rotisserie Restoration
'40 Packard 120 Convertible Coupe Restoration
How To Restore and Detail an Original Gauge Cluster
How To Detail Sand Body Panels, Edges, Corners
I've had similar results with my car at -2.5° to -3° degrees of camber all around. Street tires have no odd or unusual wear with 5K and auto-crossing. Toe will eat tires much fast than camber since it produces a grinding like effect on the edges.
