Trying to have it done by may but I doubt itll happen. I has hoping for 250+ but this turbo is too small.
time for paint and bodywork
are you doing a hybrid or a t3?
Mike, AKA the sasquatch
one is combinding two trubos from diffrent cars (EG. 323 gt hot side and a ford t-bird cold side) the 323 gt ones have boost drop off in the top end cause they cant flow enough air...
and a t3 is moe of a performance turbo that you make fit your car with a custom manifold and what ever else... they are a " universal" turbo (sort of...)Last edited by sasquatch; 03-20-2010, 08:58 PM.
i didnt do much research on this cause i wanted to go with the t3 right off the bat but is the vj14 the stock turbo? from the info i did read i hear that if you dont port the wastegate on it you will have some boost creap... and if you went with the 626 hot side and t-bird cold side it would be much better cause you wont have the boost creap and you will get more power cause the 626 hot side can flow more air...
Is that your intercooler?Originally posted by shorestiva View Post
I remember when you were trying to sell the festy and had this in your signature.
93L: money pit/ space wastersigpic
