That thing looks so nice good job.
time for paint and bodywork
hey what length and weight are those springs? i went with 7 but i think its to short. my top hat on the spring is pretty loose aroun the top i was going to use some kind of bushing to center the strut shaft better, did you have any issue with that? do you have any pics with the mounts off?
btw did you have any luck with those origns? they keep binding and wouldnt sit straight between the strut a collar
thanks
RickLast edited by Hot_Wheels; 03-10-2010, 10:46 PM.
250lb 7in springs. The top hats that came with the sleeves were plastic. So I ordered a set.of aluminum ones. The hole was too small so I drilled them out to fit. Ill try to take more pics when I pull them out again. Origns? You mean the orings that center the sleeve? No didn't have a problem with them. As long as the sleeves not moving around I think its fine.Better Than Nothing Racing
Way too many cars
:woc:
350lb 7in in backLast edited by shorestiva; 03-11-2010, 04:53 PM.Better Than Nothing Racing
Way too many cars
:woc:
looks like it will work
Mike, AKA the sasquatch
Ya that is looking pretty good
Any idea of a timeline when this thing might move under its own power?
looks good, i like how it sits
how much power are you hoping to make this time around?
