Started working on the motor today before work. Replaced water pump, timing belt and valve cover gasket (after I paint the valve cover), got it cleaned and prepped to paint. Ran into a snap with the a/c pulley,. going to need to find one for a V belt. Also switched frt motor mounts and got the ac brackets mounted on the block. Hopefully install new clutch set and tranny to motor tomorrow. Also pulled the plugs out of the spare tire well and mopped the bare interior with hot water and bleach. Its smelling much better. Ill start putting the interior back in when I get the chance. Oh yeah still have to splice the injector harness.
