everything is looking good fresh!! can't wait to see it completed!!
My first engine swap build thread
Well I hit a minor (hopefully) stumpling block.
If I get to bed soon, the motor goes in tomorrow. My friend Bob stopped by today. He drove a good bit to deliver an A/C pulley I was needing. Gave it to me, and I owe him one. Bob is a good guy and Im sure glad I bought his aspire swap cause otherwise I would have never met him. I think Im going to go with some mid 90s escort steelies like he has on his ( nice ) festiva for my aspire bolt pattern. They fit real well and look proportionate. Its the perfect wheel and tire combo for a festy IMHO. Thanks Bob !!!
Dropped the motor in this morning...by myself..another pair of hands sure would have been nice. The new tranny mount I bought had different treads than the nut the holds the mount to the cross member. I retreaded it yesterday to fit the stock nut. When I got the motor in today I couldnt get the two bolts that go through the tranny to start in the weld nuts on the new tranny mount. Then it dawned on me that those threads were probably different too. Had to pull that mount back out and retap the treads on the two weld nuts as well to fit the stock bolts. It was a pita and set me back an hour but its back in now. Got to get ready for work now, tomorrow Im going to start hooking stuff up. Its getting closer. Still have to put the aspire rear torsion beam in. Oh yeah yesterday I cleaned up all the treads in the block for the factory A/C compresser bracket and the idler pulley bracket. They were kind of rusty from non use. That was time consuming as I had to use a tap on some vise grips to do it because of lack of clearance. The devil is in the details.:evil2:
I think Im going to need a 323 down pipe. The bolt pattern on the festiva is just a hair different.sigpic
Looking awesome Fresh! Love that clean engine and bay!"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
oooo...aaahhhhhhh..... looks nice i hope mine will look as nice
Mike, AKA the sasquatch
Thanks guys !! I found another complication. You can see it in the picture below. Wished I noticed it before I put the motor in. Look where the radiator hose connects with the block, (there is duct tape covering the inlet). I went to mount the a/c compressor on the bracket just below it and it hits the inlet. Tomorrow Im going to see if I can swap the inlet tube from the festiva. It has a custom bend that misses the compressor
r.sigpic
Yep, you have to use the Festiva coolant pipe for clearance. It's a good idea to pull one if you ever get the chance in a 'yard to get to one that has been "exposed" by someone pulling other parts. Make sure you get the kit to put in a new o ring inside the part that swivels. Might have to smooth out the inside first with emory cloth, too.
Marcus, did you get your wiring issues sorted out?
If I recall right, the IAC plug splice may be "common sense." I think one wire is thicker than the other. If so, just match thicknesses.
As for the TPS, go with a matching TB or TPS from a 5 speed Protege from around '91 like I did and it should work. You just have to hog out the air plenum inlet and get the proper gasket to fit the larger TB if you go that route.
Looking really fine!
looking good fresh!! any idea when you may hear her fire up?
Originally posted by Safety Guy View PostYep, you have to use the Festiva coolant pipe for clearance. It's a good idea to pull one if you ever get the chance in a 'yard to get to one that has been "exposed" by someone pulling other parts. Make sure you get the kit to put in a new o ring inside the part that swivels. Might have to smooth out the inside first with emory cloth, too.
Karl
Originally posted by Damkid View Postlooking good fresh!! any idea when you may hear her fire up?sigpic
