I hope so but "YOU" need to come up here LOL :p
Maxtiva update
^^thats what I was thinking lol or maybe even around North Bay area?
Originally posted by Damkid View Post^^thats what I was thinking lol or maybe even around North Bay area?
Got my B-code VAF by the mail today.
I didn't forget about the video but I'm going to put the brake line for the rear before I do the video.
congrats on getting it running
now get some VIDS!!!
Mike, AKA the sasquatch
somthing still isnt right... allmost sounds like you got your spark plug wires mixed up or the ignition way out of place... it should idle fine... also you shouldnt rev it that high when its cold and hasnt run for a long time... not at all good for it
It was the third start-up yesterday and the engine was hot before I think about making a video. The car ran for about 10 min as of right now. And yes I need to figure out why it doesn't want to idle fine.
idle problem solved i tight he idle screw the engine as now around 75 min of life
I was going to suggest turning the idle up or you might have "had" a vacuum leak, but if you got it idling smooth i guess you got it figured out!!
Congrats again and now its time for some driving videos
Originally posted by sasquatch View Postsomthing still isnt right... allmost sounds like you got your spark plug wires mixed up or the ignition way out of place... it should idle fine... also you shouldnt rev it that high when its cold and hasnt run for a long time... not at all good for it
i was thinking they where mixed up cause when he hits the gas it sputters and hickups a little bit... i had two of my sparkplug wires mixed up one time and it did roughly the same thing only a bit worse... it was just a thought...
Originally posted by sasquatch View Postit was just a thought...
Originally posted by Damkid View PostI was going to suggest turning the idle up or you might have "had" a vacuum leak, but if you got it idling smooth i guess you got it figured out!!
I need to put the rear brakes lines first before driving it I'm going to do this tomorrow.
I miss having the sounds of a turbo but i am glad to see your car doing well!!
