I tried taking off the IAC and it still doesn't clear, I'll be rebuilding the whole intake once i get the intercooler
I finished cleaning up the fuel rails and got installed the 929 injectors (330cc) for the first while since i probably will only run low-ish boost at first (10-15 psi) then later i'll upgrade the turbo etc. since it's just not in the budget right now
comparison pic of before and after
both rails cleaned up
and injectors installed, they fit like factory
so thanks hppwdn for the tip on the 929 retainers
now i just gotta make an injector harness and that part of it is done at last
