My KLZE Festiva Build Thread
  • Thats what you think!
    91GL BP/F3A with boost
    • Is this turbo up and running at a decent amount of boost, or is that another project that still needs to be finished?
      • Originally posted by bhazard View Post
        Dude, my suspension is dampening adjustable as well as coil-overs, so i can stiffen up the ride quite nicely if i choose to, so with the suspension being good, what else can you suggest for traction besides tires to replace the old weather cracked POS ones i had on at FM5??
        Umm the megasquirt is to run the turbo, once the P5 is out of the garage (which should be in a week or two) then the festiva gets all the attention
        • Well, I have 250lb coilovers in the back on AGX's and turned all the way up I cant push down on the car. Even with the 205's 1st and 2nd are pretty much useless. And you have like 8 more cylindaz, nawz, squirtin, etc...
          • Well I figure i won't use the nitrous until 2nd or 3rd gear anyway, it's mainly for the last half of the track when I'll have solid traction lol
            I only plan on running 10psi at first and a decent set of tires, most likely some sort of street drag radials, and go from there
            • Originally posted by Damkid View Post
              You are going to by FLYING down that track! When are you planning on going to the tracks? Next spring, or before then?
              • ^^spring time is when it hits the track again
                • I HIGHLY recommend the Toyo Proxes T1R's for that. They get sticky FAST.
                  • That's actually the tire I was considering buying
                    • Blown tranny
                      • nitrous is like having a piggy bank in your car... each time you push the button, you have to make a payment... but in this case you cant open the bottom and get your money out when you want...
                        Mike, AKA the sasquatch
                        • Originally posted by DriverOne View Post
                          I've got them on my Stiva and they are very good and they stick very well
                          • So there's been a screw up with shipping and the MS made it to Singapore and back and now it's on it's way to me, again
                            And I've ordered a wideband
                            I was talking with a buddy of mine and if I can get my Festiva up and going by the 19th, I can get a free dyno run
                              • Wideband sounds like a must. I hope you get it going by the 19th!
