i have a centerforce on my b6t and that one worked good with that motor and i was planning on swapping them... but then i have to buy anotherone for the 323 when i sell it... im just gonna leave the stock one in and when i get boost then ill swap the clutch to a good one... or deal with it slipping for a bit lol...
sasquatch's b6t swap build thread
Mike, AKA the sasquatch
Get er done....post haha-Greg
Redneck Engineer
FOTY - '09
injector harness is done, i even tucked it down behind the fuel rail to hide it
i should have the motor in tonight
and the motor mounts dont work
back to the drawing board...
also after i took out the b6t i found out that the bp dist will fit in the b6t... that means i MAY have been able to get the b6t running on a bp computer... it may have worked, it would have been worth a try.... but i THINK just for fun ill try and put the b6t in to the parts car and try to run it on a bp ecu lol...
At least you already have the mounts.
-Greg
Redneck Engineer
FOTY - '09
Thats awesome! I did the exact same thing. How is the engine coming, do you need any help with it tomorrow? text me if you do.Originally posted by sasquatch View Postinjector harness is done, i even tucked it down behind the fuel rail to hide it
i should be getting my friends welder over to my house tomorrow and im gonna try to make a new sub frame to make the mounts work... but i may not get to that untill sunday...
thanks for the offer tim, ill text you if i need some help
^ hey where have you been?-Greg
Redneck Engineer
FOTY - '09
a little late for that now isnt it... lol jk... ill see if it works in the parts car... im just gonna use the stock transOriginally posted by grocerygetter View PostI told you it should work. All you have to do is use the bp distributor and vaf and disregard the knock box on the b6t.
lets hope he has been making his festiva faster....Originally posted by eurotiva View Post^ hey where have you been?
in my red car ill use the 323 gt trans but in the white car ill use the stock one...
As per eurotiva......ive been busily preparing my festiva for the assault on the 11's!!!! Should be doable with this years changes.
New enginemanagement....imagine a crome tunable mazda and you get the idea
Watermeth with 550cc injectors
And if its as scary as I anticipate....a 6 point cage
And a fresh coat of flat black for the hood
I'm looking forward to racing mike at the track this year!!!
