Originally posted by bhearts
Tom's B6 Build Thread
No, just my first setup was easier to do the vc-Greg
Redneck Engineer
FOTY - '09
Is that oil feed line epoxied in there?Originally posted by eurotiva View PostThat's funny Mike. Glad you got yours back up and running.
Time for an update...............
It's been unusually cold here (30s-40s) So progress has been slow. I got everything ready for installation.
Here's the oil pan Before.....
After.............
Got the lower portion of the timing cover finished and installed...............
Also got the oil feed and oil return installed......................................... ..................
More updates coming soon
.................................................. ..................1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Liquid Teflon. Way easier than tape, but way more mess-Greg
Redneck Engineer
FOTY - '09
Hmm, is there a difference between the flow rate of the 2nd gen B6 Brown Injectors compared to the 1st B6 Green injectors?
Just a thought, since maybe it would be running a bit richer, or leaner if the flow rates are different, because I am of course using a 1st gen B6 on a 2nd Gen B6 ecu and VAF.
This could possibly be why it has some running issues, and doesn't feel quite like 80 horsepower.Last edited by TorqueEffect; 09-25-2014, 04:59 PM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Those were in the b6 when we got it? I'm not sure if they were stock, they came from a crashed b6 Festiva-Greg
Redneck Engineer
FOTY - '09
Yeah they sure did, looked up the injectors on Rockauto between 1st gen and 2nd gen B6s, and they are different. Those are the injectors that came with that engine from the factory.Originally posted by eurotiva View PostThose were in the b6 when we got it? I'm not sure if they were stock, they came from a crashed b6 Festiva
I am just wondering if anyone knows whether the flow is different between the First Gen Green ones, and the Second Gen Brown ones? I am guessing it is different, but just seeing if someone might know.Last edited by TorqueEffect; 09-25-2014, 05:16 PM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Witchhunter.com has images and numbers-Greg
Redneck Engineer
FOTY - '09
Thanks for the link.
Found the 1st gen Dark Green Injectors are 220cc, now to find the 2nd gen injectors.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Great site for injector info. Thanks for those pics-Greg
Redneck Engineer
FOTY - '09
No problem.Originally posted by eurotiva View PostGreat site for injector info. Thanks for those pics
But yeah I can't seem to find any info on the 2nd Gen B6 injectors, both the site you linked me to didn't even list the 2nd gen injectors, and the site with the flow chart I found, the info on them was completely blank.
Guess I will just need to find 4 2nd gen B6 injectors and try them out. Probably see if anyone has some to throw away on clubprotege. They don't care for B6s over there. lol :pLast edited by TorqueEffect; 09-25-2014, 09:06 PM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Greg off topi here but what paint do you use on the valve cover I seen that look on several of the cars you built on here.
Looks like a factory aluminum finish I like it.
I'm looking for something like that for my Transmission.
Bp injectors are 260?-Greg
Redneck Engineer
FOTY - '09
Close 254ccOriginally posted by eurotiva View PostBp injectors are 260?
Nippondenso Part number for BP injectors is 195500-2180
Stock Festiva B3 is 195500-2110 flow only being 122cc.
I take it back, I can't verify any flow ratings for any B6 injectors.
But here are the Denso part numbers.
First gen B6 part# 195500-1670
Second gen B6 part# 195500-2120Last edited by TorqueEffect; 09-26-2014, 01:25 AM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
