My b6t Capri Engine/Trans swap
  • #16
    That is the problem. I have read a couple different things along the way. Just trying to get a definitive answer. I might just have to try some things myself and report back.
    • #17
      Same here, Im going with festy lca's first.
      Im just praying that my 15" xr2 wheels and 195-50-15's fit since my metro 13"s most likely wont.
      91GL BP/F3A with boost
      • #18
        My XR2 had 14's on it. They are a decent set of matched rims with 185/60R14 tires. Plan on giving them a whirl on the Festiva when I start the mods. Maybe move to a different rim down the road.
        To those stripping out the XR2, the speedo cables are no longer made, even aftermarket. I got $40 shipped for mine. $30 in my pocket.
        • #19
          SO, my first downfall is the transmission. It shifted fine and moved in every gear without any grinding or trans noises when in the Capri. There was a wicked CV thump on the passenger side, but that was the biggest issue. When I separated the engine/trans today, I noticed there is a hole inside the bellhousing. Goes into the diff area. You can see the gears where the axle shafts fit in!
          I have another trans that I had already snagged. Good thing I guess.
